Salta al contenuto principale
Sony SLT Alpha-65V LCD Screen Replacement
Alexander Lisso
Alexander Lisso e 3 altri collaboratori
Ultimo aggiornamento il 3 nov 2022
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to unscrew the LCD screen housing from the back of the camera and disconnect the screen's circuitry from the circuitry of the rest of the camera. This requires using a Phillips #00 screwdriver and a plastic opening tool to remove the screen. It is very helpful to use a magnetic pad to organize and keep track of all the screws removed from the camera.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Sony SLT Alpha-65V LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 2 Sony SLT Alpha-65V LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 2
    • Remove the two 4.0 mm Phillips #00 screws on the base of the camera.
    • Remove the 3.0 mm Phillips #00 screw on the hinge of the screen.
  2. Sony SLT Alpha-65V LCD Screen Replacement: passo 2, immagine 1 di 2 Sony SLT Alpha-65V LCD Screen Replacement: passo 2, immagine 2 di 2
    • Remove the two 2.0 mm Phillips #00 screws on the bottom-right side of the screen.
    • Remove the two 2.0 mm Phillips #00 screws on the bottom-left side of the screen.
  3. Sony SLT Alpha-65V LCD Screen Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to gently pry the screen open around the entire screen.
  4. Sony SLT Alpha-65V LCD Screen Replacement: passo 4, immagine 1 di 3 Sony SLT Alpha-65V LCD Screen Replacement: passo 4, immagine 2 di 3 Sony SLT Alpha-65V LCD Screen Replacement: passo 4, immagine 3 di 3
    • The brown ribbon and white light on the edge of the screen are extremely loose and will fall off off. Keep the screen flat at all times to make sure they don't come out.
    • Use a plastic opening tool to disconnect the silver wires from the screen's circuitry and completely remove the screen from the camera.
    Hi thank you for the post I have managed to do this. But unfortunately broken one of the multi connection wires as shown in your image 4 please can you suggest what are my options. Thanks
    Vengo2005 - Replica
    Hi I have broken one of the wire from the metal looking connector. As shown in the step 4 image. Could you suggest me my options. Thank you. Hope fully not replace the camera
    Vengo2005 - Replica
    How do you open the plastic cover holding the lcd screen itself after ? It seems sealed :(
    thefirestarter - Replica
Conclusione
Altre 8 persone hanno completato questa guida.
Cal Poly, Team 14-11, Amido Spring 2015 Membro di Cal Poly, Team 14-11, Amido Spring 2015
CPSU-AMIDO-S15S14G11
4 Membri
13 Guide realizzate
4Commenti sulla guida
hello everyone, thank you so much for this repair, I did that with my sony camera but it doesn’t work, how to know if its not the motherboard behind the screen that doesnt work or the flex cable, because the camera works perfectly just no screen, thank you in advance
Acèn - Replica
my father used to repair black and white tv in the 80's here in the country of PERU, so I thought, my father repairs tv I must have inherited the skill so I will repair my a77v camera, result = I messed up more xD.
At the moment the screen did not emit an image, it went all black, when I uncovered the screen I found a pcb which was missing a component, I started cleaning with a toothbrush and 2 more components came off, I could not identify if they are resistors, capacitors or diodes, I looked for the schematic on the web but I didn't find anything related, could you help me identify which components are missing? Is there a way to upload an image here to show where they came off? I will be very grateful, ATTE: a friend from Peru.
ruben omar mamani saga - Replica
Thanks for the Tutorial, I miss however the Part Number for a new disolay and maybe a source where to buy.
Regards
Willie
Wilfried Neumann - Replica
Das hat wunderbar funktioniert. Man darf nicht grob beim Aufschrauben sein, vor allen Dingen, wenn man das Gehäuse öffnet. Die Kabel darin sind sehr empfindlich. Vielen Dank! Die Displays gibt es für kleines Geld im Onlinehandel.
Heiner Klobbit - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 35
Tutti i Tempi: 5,902
