Salta al contenuto principale
Sony KDF-E60A20 Lamp Replacement
oldturkey03
oldturkey03 e 2 altri collaboratori
Ultimo aggiornamento il June 16, 2020
15 - 30 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Here is a Sony TV that turned on and off every few seconds. To remedy this, replace the lamp. This is straight forward and only requires a small Allen wrench. As with all work on all electric or electronic equipment, make sure that it is unplugged first.
  1. Sony KDF-E60A20 Lamp Replacement, Lamp: passo 1, immagine 1 di 3 Sony KDF-E60A20 Lamp Replacement, Lamp: passo 1, immagine 2 di 3 Sony KDF-E60A20 Lamp Replacement, Lamp: passo 1, immagine 3 di 3
    • Remove the two thumb screws.
  2. Sony KDF-E60A20 Lamp Replacement: passo 2, immagine 1 di 3 Sony KDF-E60A20 Lamp Replacement: passo 2, immagine 2 di 3 Sony KDF-E60A20 Lamp Replacement: passo 2, immagine 3 di 3
    • With both thumb screws removed, the front bezel can now be easily pulled off. It is only held in place by three magnets.
    • With the bezel out of the way, there will be a small cover held in place by a crossbar and a thumb screw. Loosen the thumb screw and fold the bar out of the way.
    • The back of the lamp housing is now visible.
  3. Sony KDF-E60A20 Lamp Replacement: passo 3, immagine 1 di 3 Sony KDF-E60A20 Lamp Replacement: passo 3, immagine 2 di 3 Sony KDF-E60A20 Lamp Replacement: passo 3, immagine 3 di 3
    • Loosen the 3mm Allen bolt. It will not come out of the lamp housing, but will loosen it to remove the lamp housing from the TV.
    • With the Allen bolt loose, pull the lamp houing slightly back and down,
    • this will remove the lamp in its housing.
  4. Sony KDF-E60A20 Lamp Replacement: passo 4, immagine 1 di 3 Sony KDF-E60A20 Lamp Replacement: passo 4, immagine 2 di 3 Sony KDF-E60A20 Lamp Replacement: passo 4, immagine 3 di 3
    • Here is the old lamp and housing.
    • For the replacement, a complete lamp and housing was chosen. The lamp is individually available. There was not a big difference in cost, to justify the additional steps of replacing the lamp housing.
    • Install the new lamp and housing
  5. Sony KDF-E60A20 Lamp Replacement: passo 5, immagine 1 di 1
    • Result of this $32 repair is a bright fully functioning TV
Conclusione
Altre 13 persone hanno completato questa guida.
oldturkey03
Membro da: 09/29/10
812.145 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
45 Membri
702 Guide realizzate
17 Commenti
Where did you purchase this bulb for $32?
Wendy Watson - Replica
Mine worked 4 3 hours then stayed off.
Love machine Guaranteed -
I ordered a replacement housing with new bulb in it and with shipping it was 35. Ordered it thru Sears online and they sent it out next day air. It took five min to swap out
Joker - Replica
Thanks a lot. You saved me money
Alexander Ritchie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 38
Tutti i Tempi: 25,339
