Salta al contenuto principale
Sony Cyber-shot DSC-P52 LCD Replacement
Mark
Mark e 6 altri collaboratori
Ultimo aggiornamento il December 3, 2020
15 - 20 minuti
Moderato
Introduzione
Vai al passo 1
The LCD should be checked if the screen is blank or broken.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Sony Cyber-shot DSC-P52 LCD Replacement, Outer Case: passo 1, immagine 1 di 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 LCD Replacement: passo 2, immagine 1 di 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 LCD Replacement: passo 3, immagine 1 di 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 LCD Replacement: passo 4, immagine 1 di 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 LCD Replacement: passo 5, immagine 1 di 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 LCD Replacement: passo 6, immagine 1 di 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 LCD Replacement: passo 7, immagine 1 di 1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 LCD Replacement, Sony Cyber-shot DSC-P52 Removing Ribbon Cables: passo 8, immagine 1 di 1
    • Unclip the ribbon cable shown the in picture.
    • Some ribbon cables do not have a clip holding them in.
  9. Sony Cyber-shot DSC-P52 LCD Replacement: passo 9, immagine 1 di 1
  10. Sony Cyber-shot DSC-P52 LCD Replacement, LCD: passo 10, immagine 1 di 1
    • Remove 7 Screws to remove plate and expose LCD screen.
  11. Sony Cyber-shot DSC-P52 LCD Replacement: passo 11, immagine 1 di 1
    • Remove LCD plate to expose LCD components and ribbon cables
  12. Sony Cyber-shot DSC-P52 LCD Replacement: passo 12, immagine 1 di 1
    • Check connection of LCD to cables
    • If cables are intact, disconnect cables and replace LCD with new part
  13. Sony Cyber-shot DSC-P52 LCD Replacement: passo 13, immagine 1 di 1
    • Repeat steps in reverse order to reassemble the camera
Conclusione
Mark
Membro da: 01/11/11
16 Reputazione
1 Guida realizzata
Cal Poly, Team 3-43, Regan Winter 2011 Membro di Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Membri
20 Guide realizzate
1Commento della guida
I don’t know the cause of my camera not turning on.
Smgmc64 Productions - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,618
