Salta al contenuto principale
Sony Cyber-shot DSC-HX300 LCD Screen Replacement
Elizabeth Surface
Elizabeth Surface e 10 altri collaboratori
Ultimo aggiornamento il 10 gen 2025
30 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
Use this guide to replace the LCD screen of your Sony Cyber-shot DSC-HX300.
The LCD (liquid-crystal display) screen is a flat panel that uses liquid crystals, polarizers, and a backlight or reflector to display images. Without the LCD screen, the user is unable to access some information or the image gallery.
If the LCD screen is not powering on after the LCD/Finder button has been pressed twice, then the screen may need to be replaced.
Before starting this guide, make sure to review the repair page. There may be charging or battery issues that are causing issues rather than the LCD screen itself.
Make sure to turn off your camera before starting this guide.
Cosa ti serve
Strumenti
Mostra di più…
  1. Sony Cyber-shot DSC-HX300 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 LCD Screen Replacement, LCD Screen: passo 5, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down the camera, remove the battery, and unplug your device before you begin.
    • Use a Phillips head screwdriver to remove one 2 cm screw located on the inside portion of the LCD hinge.
  6. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 6, immagine 2 di 2
    • While using a plastic opening tool, carefully remove the plastic housing that surrounds the hinge.
  7. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 7, immagine 1 di 2 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 7, immagine 2 di 2
    • Using a small Phillips head screwdriver, remove the (2) 2 cm screws on the back of the LCD display, as indicated in the photo.
    • Turn the camera on its side to access the last remaining 2 cm Phillips head screw holding the LCD case together.
  8. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Remove the plastic cover from the back of the LCD display by simply sliding it up and off of the camera.
  9. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 9, immagine 1 di 2 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 9, immagine 2 di 2
    • Using a plastic opening tool, carefully remove the plastic housing that surrounds the LCD display.
  10. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 10, immagine 1 di 3 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 10, immagine 2 di 3 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 10, immagine 3 di 3
    • Once the plastic housing is separated, disconnect the ribbon wire located on the back of the LCD display. This can be achieved by pulling up lightly on the brown bar that locks the ribbon wire to the circuit board..
    • Disconnect the remaining two ribbon wires the same way. They are located on the right, rear side of the LCD frame.
  11. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 11, immagine 1 di 1
    • Using a small Phillips head screwdriver, remove the last 2 cm screw that mounts the circuit board to the metal LCD display frame.
  12. Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 12, immagine 1 di 2 Sony Cyber-shot DSC-HX300 LCD Screen Replacement: passo 12, immagine 2 di 2
    • Once the circuit board is removed the replacement parts can be installed in the reverse order.
Conclusione
To reassemble your device, follow these instructions in reverse order. It is important to follow the steps in this order as it may not turn on properly if the user does not follow every step.
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 4-6, Meier Fall 2015 Membro di USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Membri
18 Guide realizzate
3Commenti sulla guida
my screen is working but in negative effect, any ideas??
wilmer - Replica
Comment réparer la carte circuit imprimé de l'écran? Il y'a un transistor qui reçoit 3.7v et qui laisse rien sortir
Abdoul Traore - Replica
my screen was showing vertical red and green lines but you could read the settings. Now the lcd screen is white. Can the lcd be replaced?
yuclin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,652
