Salta al contenuto principale
Sony Alpha NEX-6 LCD Screen Replacement
Clayton Dale
Clayton Dale e 3 altri collaboratori
Ultimo aggiornamento il May 7, 2024
15 - 30 minuti
Difficile
Introduzione
Vai al passo 1
This guide will begin by taking off back cover of screen assembly. The guide will then explain how to uncover and disconnect the LCD Ribbon cable. The screen will then be removed from the screen mount assembly.
Cosa ti serve
Strumenti
Mostra di più…
  1. Sony Alpha NEX-6 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
  2. Sony Alpha NEX-6 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
  3. Sony Alpha NEX-6 LCD Screen Replacement: passo 3, immagine 1 di 1
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
  4. Sony Alpha NEX-6 LCD Screen Replacement, Removing back screws: passo 4, immagine 1 di 1
    • Remove the two 1.0 mm Phillips #00 screws from back of the LCD screen.
  5. Sony Alpha NEX-6 LCD Screen Replacement, Removing bottom screws: passo 5, immagine 1 di 1
    • Remove the two 1.5 mm Phillips #00 screws from the bottom of the screen mount assembly.
  6. Sony Alpha NEX-6 LCD Screen Replacement, Back cover: passo 6, immagine 1 di 2 Sony Alpha NEX-6 LCD Screen Replacement, Back cover: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Using a plastic opening tool pry off the back cover from the screen assembly.
    • Remove back cover by lifting it away from the screen using tweezers.
  7. Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: passo 7, immagine 1 di 3 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: passo 7, immagine 2 di 3 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: passo 7, immagine 3 di 3
    • Release the ribbon cable by lifting the black locking latch with the plastic opening tool.
    • Pry out the ribbon cable by carefully sliding it out of the connection slot using a spudger.
  8. Sony Alpha NEX-6 LCD Screen Replacement, Upper plastic separator: passo 8, immagine 1 di 1
    • Lift and slide out the upper black plastic separator using tweezers.
  9. Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: passo 9, immagine 1 di 3 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: passo 9, immagine 2 di 3 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: passo 9, immagine 3 di 3
    • Lift and remove the lower black plastic separator using tweezers.
    • Using the pointy side of a spudger push in the screen lock button release it.
    • The screen lock button can now be removed.
  10. Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: passo 10, immagine 1 di 3 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: passo 10, immagine 2 di 3 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: passo 10, immagine 3 di 3
    • Using the flat end of the spudger, push on the black nylon sheet glued to the metallic frame to peel it of.
    • Apply force from different spots to avoid tearing the sheet.
    • Remove the black nylon sheet using tweezers.
  11. Sony Alpha NEX-6 LCD Screen Replacement, Screen Removal: passo 11, immagine 1 di 1
    • Gently wiggle the screen loose and remove it from the mount.
Conclusione
Altre 6 persone hanno completato questa guida.
Clayton Dale
Membro da: 01/20/15
1.067 Reputazione
7 Guide realizzate
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro di USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Membri
14 Guide realizzate
2Commenti sulla guida
Thanks a million! Great guide and saved me $250 sending it back in.
Al Weiner - Replica
Hi - I am trying to fix one of these -- and the guy I bought it from pulled off and lost the black locking latch from the ribbon cable rather than just lifting it -- I can get the LCD screen to light but can't keep it on very long -- I bought another one of these internal cables with the black locking latch. Do you think I can pop that one off and move it to this one? Or do you have any source of instructions how to replace that cable?
Cheers and thanks for this!
PS -- If anyone is just trying to get rid of the dreaded bubbles in the screen saver that plagues these NEX cameras -- it does just peal off -- see youtubes,,,
Harvey Cat - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 76
Tutti i Tempi: 7,140
