Salta al contenuto principale
Sony Alpha 5100 LCD Replacement
Kevin Raggiani
Kevin Raggiani e 3 altri collaboratori
Ultimo aggiornamento il 23 dic 2020
10 - 20 minuti
Moderato
Passi mancanti
Introduzione
Vai al passo 1
This guide will be showing you how to get into the back of the LCD screen on the Sony Alpha 5100 (ILCE-5100/5100L). This guide will help if you are having trouble with the camera screen not working. Since we are exposing the electronics underneath the screen, do not expose the inside to water.
Cosa ti serve
Strumenti
  1. Sony Alpha 5100 LCD Replacement, LCD: passo 1, immagine 1 di 1
    • Slide the power switch on the top of the camera to "off."
  2. Sony Alpha 5100 LCD Replacement: passo 2, immagine 1 di 1
    • Flip the LCD screen so that you have access to the back of the screen. The front of the screen should be facing the direction that the lens is facing.
  3. Sony Alpha 5100 LCD Replacement: passo 3, immagine 1 di 2 Sony Alpha 5100 LCD Replacement: passo 3, immagine 2 di 2
    • Remove the two 2mm Phillips #00 screws on the back of the screen.
    • Remove the two 2mm Phillips #00 screws on the top of the LCD screen.
  4. Sony Alpha 5100 LCD Replacement: passo 4, immagine 1 di 1
    • Carefully pry open the back plate off the screen with an iFixit opening tool.
    • If separating the plates is giving you trouble, aim for the notch at the bottom of the plate.
  5. Sony Alpha 5100 LCD Replacement: passo 5, immagine 1 di 2 Sony Alpha 5100 LCD Replacement: passo 5, immagine 2 di 2
    • Carefully open the back plate of the screen.
Conclusione
Altre 3 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
1Commento della guida
Hello, thank you for this but it’s only half the steps, how to remove the LCD and touch screen after step 5? Something else is holding it in place. Can lift the outer edge a little only. Possibly it is glue or tape? My touchscreen is always active and focus rectangle moving around the lower part of screen. Can touch screen and it will go there but soon moves back to lower area.
Thank you.
John Meldrum - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 36
Tutti i Tempi: 2,217
