Salta al contenuto principale
Solving slow moving ceiling fan with remote control
SengChoy Liew
SengChoy Liew e 2 altri collaboratori
Ultimo aggiornamento il June 26, 2024
25 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
If the ceiling fan comes with a remote control to switch on and off moving really slow at maximum speed. This video guide will definitely helps solving it.
Panoramica Video
  1. Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): passo 1, immagine 1 di 3 Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): passo 1, immagine 2 di 3 Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): passo 1, immagine 3 di 3
    • Specification for capacitor are sometimes printed at the size. This brand uses 0.82uF 275V capacitor. Specification varies with brand.
  2. Solving slow moving ceiling fan with remote control: passo 2, immagine 1 di 1
    • It will be so much easier if the board can be clamp down using the board repair clamp to hold the board while desoldering the correct capacitor.
  3. Solving slow moving ceiling fan with remote control: passo 3, immagine 1 di 1
    • Simple suction pump required to remove the molten fuse.
  4. Solving slow moving ceiling fan with remote control: passo 4, immagine 1 di 1
    • Cut off the excess length using a tiny cutter after a new capacitor is being soldered onto the board.
  5. Solving slow moving ceiling fan with remote control: passo 5, immagine 1 di 1
    • Test the fan if it is moving at maximum speed after the capacitor is being replaced before assembling it.
Conclusione
Test the board if working before reassembly the circuit board back into the ceiling fan.
1Commento della guida
Not worth it, going to trash it & buy simple fan.
Joe W - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 56
Tutti i Tempi: 4,294
