Shark Rotator Powered Lift-Away Speed Roller Brush Replacement
Introduzione
Vai al passo 1The roller brush can have debris that will cause the vacuum to not work properly. It is important that you always clean your roller brush after every use, so that your Shark Rotator Powered Lift Away Speed Vacuum can perform at it's best. This guide will show you how to change your roller brush if it becomes damaged or is broken.
Cosa ti serve
Turn the vacuum on its side.
Using a quarter, twist the three green locks to the unlock position.
Pull the bottom roller brush cover to open the vacuum.
Altre 10 persone hanno completato questa guida.
13 Commenti
Exactly, I struggled for sometime trying to find that 1 little screw that was a Phillips head.
I figured out how to get it apart… Where do I find a new roller?
where can i get a new roller also...
