Samsung SPEX SCH-R210 Back Cover Replacement
Introduzione
Vai al passo 1We will be showing you the easiest way to take the back cover off the Samsung SPEX SCH-R210 phone to access the battery and other components of the phone.
Lay the phone on its front side so the back is visible.
Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
Slide the cover down from the phone to remove it. Set the cover aside.
1Commento della guida
uh, this is so easy that I’m pretty sure it doesn’t need a guide for it. I found an old Spex (perfect condition except for a few flaws) and I knew how to take off the cover from day 1, but it’s nice you made this anyway. Thx ig
