Salta al contenuto principale
Samsung Refrigerator Icemaker Assembly Replacement
Cosa ti serve
    1. Samsung Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: passo 2, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: passo 2, immagine 2 di 2
      • Open both French doors for the refrigerator compartment.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: passo 3, immagine 1 di 1
      • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: passo 4, immagine 1 di 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: passo 4, immagine 2 di 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: passo 4, immagine 3 di 3
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung Refrigerator Icemaker Assembly Replacement, Check the ice bucket condition: passo 5, immagine 1 di 1
      • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
      • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: passo 6, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: passo 6, immagine 2 di 2
      • Remove the wire harness screw securing the cable cover panel.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: passo 7, immagine 1 di 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: passo 7, immagine 2 di 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: passo 7, immagine 3 di 3
      • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
      • Remove the cable cover panel.
      • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: passo 8, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: passo 8, immagine 2 di 2
      • The exact configuration of the connectors may vary on your refrigerator.
      • Disconnect the left-most yellow connector:
      • Squeeze the locking tab with your fingers.
      • Rock the connector gently side to side to disconnect it.
      • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: passo 9, immagine 1 di 1
      • Remove the ice maker screw securing the air tunnel flap.
      Chiedi a FixBot
      Aggiungi Commento
    5. Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: passo 10, immagine 1 di 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: passo 10, immagine 2 di 3 Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: passo 10, immagine 3 di 3
      • A plastic clip holds the air tunnel flap in place.
      • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
      Chiedi a FixBot
      Aggiungi Commento
    6. Samsung Refrigerator Icemaker Assembly Replacement: passo 11, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement: passo 11, immagine 2 di 2
      • Use your fingers to pull the air tunnel flap down enough to access the internals.
      Chiedi a FixBot
      Aggiungi Commento
    7. Samsung Refrigerator Icemaker Assembly Replacement: passo 12, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement: passo 12, immagine 2 di 2
      • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
      • During reassembly, use your fingers to push the refrigerant loop back up.
      Chiedi a FixBot
      Aggiungi Commento
    8. Samsung Refrigerator Icemaker Assembly Replacement: passo 13, immagine 1 di 3 Samsung Refrigerator Icemaker Assembly Replacement: passo 13, immagine 2 di 3 Samsung Refrigerator Icemaker Assembly Replacement: passo 13, immagine 3 di 3
      • A plastic clip holds the icemaker in place.
      • Use your fingers to press and release the plastic clip.
      • This clip is stiff and may require substantial force.
      Chiedi a FixBot
      Aggiungi Commento
    9. Samsung Refrigerator Icemaker Assembly Replacement: passo 14, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement: passo 14, immagine 2 di 2
      • Pull the front edge of the icemaker assembly down slightly to loosen it.
      • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
      • Carefully slide the icemaker assembly out of its housing.
      Chiedi a FixBot
      Aggiungi Commento
    10. Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: passo 15, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: passo 15, immagine 2 di 2
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Be sure to dry any moisture that remains in the ice room before reassembly to prevent repair failure.
Repair didn’t go as planned? Ask our Answers Community for help.
Altre 3 persone hanno completato questa guida.
nicO
Membro da: 04/14/15
15.990 Reputazione
89 guide realizzate
Team Vulcan Membro di Team Vulcan
Staff
6 Membri
914 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 16
Ultimi 7 giorni: 250
Ultimi 30 giorni: 1,287
Tutti i Tempi: 27,806
