Salta al contenuto principale
Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker)
Cosa ti serve
    1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unplug your refrigerator: passo 1, immagine 1 di 1
      • Unplug your refrigerator before you begin your repair.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: passo 2, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: passo 2, immagine 2 di 2
      • Slide the freezer drawer fully open.
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: passo 3, immagine 1 di 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: passo 3, immagine 2 di 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: passo 3, immagine 3 di 3
      • Lift and remove all the freezer bins from the drawer.
      • You may need to open the refrigerator doors in order to remove the large bin.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: passo 4, immagine 1 di 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: passo 4, immagine 2 di 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: passo 4, immagine 3 di 3
      • A plastic tab locks each drawer rail in place.
      • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
      • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
      Chiedi a FixBot
      Aggiungi Commento
    5. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 5, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 5, immagine 2 di 2
      • Repeat the rail unlock procedure on the other drawer rail.
      • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
      • Remove the freezer drawer.
      • To install the freezer drawer:
      • Push the geared torsion bar until it rests at the very end of the rails.
      • Align the drawer rails to the refrigerator wall guides.
      • Close the freezer drawer until the rails lock back in place.
      • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
      Chiedi a FixBot
      Aggiungi Commento
    6. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: passo 6, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: passo 6, immagine 2 di 2
      • Use a Phillips screwdriver to remove the screws securing the icemaker assembly to the freezer ceiling.
      Chiedi a FixBot
      Aggiungi Commento
    7. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: passo 7, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: passo 7, immagine 2 di 2
      • Grasp the front edge of the icemaker assembly and tilt it downwards.
      • Don't try to remove the icemaker yet, as it's still connected by a few wires.
      Chiedi a FixBot
      Aggiungi Commento
    8. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 8, immagine 1 di 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 8, immagine 2 di 2
      • Use your fingers to guide the wire harness out of the icemaker assembly.
      Chiedi a FixBot
      Aggiungi Commento
    9. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 9, immagine 1 di 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 9, immagine 2 di 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 9, immagine 3 di 3
      • Squeeze the icemaker cable connector and pull to disconnect it.
      Chiedi a FixBot
      Aggiungi Commento
    10. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): passo 10, immagine 1 di 1
      • Remove the icemaker assembly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Altre 2 persone hanno completato questa guida.
Arthur Shi
Membro da: 01/03/18
345.049 Reputazione
915 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
53.155 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 29
Ultimi 30 giorni: 144
Tutti i Tempi: 2,245
