Salta al contenuto principale
Samsung Galaxy Tab S7 Plus Rear Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Heat the bottom edge: passo 1, immagine 1 di 1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for three minutes to loosen the adhesive underneath.
    • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  2. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Screen removal information: passo 2, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Screen removal information: passo 2, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Screen removal information: passo 2, immagine 3 di 3
    • While you're waiting for the adhesive to loosen, note the following:
    • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
    • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
    • This image shows an example of a damaged display separating from the glass panel.
    • Don't insert the pick more than 3 mm to avoid damaging the display.
  3. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Insert an opening pick: passo 3, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Insert an opening pick: passo 3, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Insert an opening pick: passo 3, immagine 3 di 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the bottom adhesive: passo 4, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the bottom adhesive: passo 4, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the bottom adhesive: passo 4, immagine 3 di 3
    • Insert a new opening pick into the gap you created.
    • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
  5. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Heat the right edge: passo 5, immagine 1 di 1
    • Apply a heated iOpener to the right edge of the device for two minutes to loosen the adhesive underneath.
  6. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the bottom-right corner adhesive: passo 6, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the bottom-right corner adhesive: passo 6, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the bottom-right corner adhesive: passo 6, immagine 3 di 3
    • Rotate the opening pick around the bottom-right corner of the device.
  7. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the right edge: passo 7, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the right edge: passo 7, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the right edge: passo 7, immagine 3 di 3
    • Insert a new opening pick into the gap you created at the bottom right corner.
    • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
    • Slide the new pick along the right edge of the device towards the top-right corner.
  8. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Heat the top edge: passo 8, immagine 1 di 1
    • Apply a heated iOpener to the top edge of the device for two minutes to loosen the adhesive underneath.
  9. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the top-right corner adhesive: passo 9, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the top-right corner adhesive: passo 9, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the top-right corner adhesive: passo 9, immagine 3 di 3
    • Rotate the opening pick around the top-right corner of the device.
  10. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the top adhesive: passo 10, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the top adhesive: passo 10, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the top adhesive: passo 10, immagine 3 di 3
    • Slide the new pick along the top edge of the device towards the top-left corner.
  11. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Heat the left edge: passo 11, immagine 1 di 1
    • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
  12. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the top-left corner adhesive: passo 12, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the top-left corner adhesive: passo 12, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the top-left corner adhesive: passo 12, immagine 3 di 3
    • Rotate the opening pick around the top-left corner of the device.
  13. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the left adhesive: passo 13, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the left adhesive: passo 13, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the left adhesive: passo 13, immagine 3 di 3
    • Slide the new pick along the left edge of the device towards the bottom-left corner.
  14. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the bottom-left corner adhesive: passo 14, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the bottom-left corner adhesive: passo 14, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the bottom-left corner adhesive: passo 14, immagine 3 di 3
    • Rotate the opening pick around the bottom-left corner of the device.
    • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
  15. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the screen: passo 15, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the screen: passo 15, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the screen: passo 15, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Don't try to remove the screen all the way yet; it's still connected by a flex cable.
    • With the top of the device facing you, lift the bottom edge of the screen up and away from you like you're opening a book.
    • Rest the screen upside down before continuing.
    • Be careful not to strain the flex cable.
    • During reassembly:
    • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the display cable: passo 16, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the display cable: passo 16, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector from the back of the screen.
    • Be careful not to damage the wide display flex ribbons on the bottom edge of the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Samsung Galaxy Tab S7 Plus Rear Camera Replacement: passo 17, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement: passo 17, immagine 2 di 2
    • Use tweezers, or your fingers, to hold the display cable in place.
    • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
    • Take note of the display cable's position—you'll need to bend it in the same way when connecting a new screen.
  18. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the screen: passo 18, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the screen: passo 18, immagine 2 di 2
    • Remove the screen from the frame.
  19. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Unfasten the frame bracket: passo 19, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Unfasten the frame bracket: passo 19, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Unfasten the frame bracket: passo 19, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the fifty 3 mm-long screws securing the frame bracket to the frame.
    • The third photo has the same screws marked by quadrant. Use this photo during reassembly to help account for all the screws:
    • Bottom-left = 9 screws
    • Bottom-right = 14 screws
    • Top-right = 12 screws
    • Top-left = 15 screws
  20. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the frame bracket: passo 20, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the frame bracket: passo 20, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the frame bracket: passo 20, immagine 3 di 3
    • Lift the frame bracket away from the frame, making sure to thread the display cable through its socket.
  21. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the battery: passo 21, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the battery: passo 21, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the battery's press connector secured to the motherboard.
  22. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the display cable: passo 22, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the display cable: passo 22, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the display cable: passo 22, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the motherboard.
    • Repeat for the fingerprint sensor cable attached to display cable.
  23. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the display cable: passo 23, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the display cable: passo 23, immagine 2 di 2
    • Use your fingers to remove the display cable.
  24. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the daughterboard interconnect cable: passo 24, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the daughterboard interconnect cable: passo 24, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the daughterboard interconnect cable's press connector secured to the motherboard.
  25. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the keyboard dock port cable: passo 25, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the keyboard dock port cable: passo 25, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the keyboard dock port cable's press connector secured to the motherboard.
  26. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the front camera: passo 26, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the front camera: passo 26, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the front camera: passo 26, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the front camera's press connector secured to the motherboard.
    • Use tweezers, or your fingers, to remove the front camera.
  27. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the microSD card reader: passo 27, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the microSD card reader: passo 27, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the microSD card reader's press connector secured to the motherboard.
  28. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the 5G antenna: passo 28, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the 5G antenna: passo 28, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the 5G antenna's press connector secured to the motherboard.
  29. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the 5G antenna: passo 29, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the 5G antenna: passo 29, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the 5G antenna: passo 29, immagine 3 di 3
    • Use tweezers to pull the antenna out of the frame by its bracket.
    • Remove the 5G antenna.
  30. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the left coaxial cables: passo 30, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the left coaxial cables: passo 30, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the left coaxial cables: passo 30, immagine 3 di 3
    • Use the point of a spudger to carefully pry up and disconnect the green coaxial cable from the left side of the motherboard.
    • Repeat this process for the red coaxial cable.
  31. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the rear camera: passo 31, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the rear camera: passo 31, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the rear camera: passo 31, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the rear camera's two press connectors secured to the motherboard.
  32. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the power button cable: passo 32, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the power button cable: passo 32, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the power button cable's press connector secured to the motherboard.
  33. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the bottom-right coaxial cable: passo 33, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the bottom-right coaxial cable: passo 33, immagine 2 di 2
    • Use the point of a spudger to carefully pry up and disconnect the bottom-right loudspeaker's yellow coaxial cable from the motherboard.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  34. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Reposition the bottom-right coaxial cable: passo 34, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Reposition the bottom-right coaxial cable: passo 34, immagine 2 di 2
    • Pull the coaxial cable away from the frame, making sure the cable is completely unthreaded from the motherboard.
  35. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the interconnect cable: passo 35, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the interconnect cable: passo 35, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable's press connector secured to the motherboard.
  36. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the top-right coaxial cables: passo 36, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the top-right coaxial cables: passo 36, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Disconnect the top-right coaxial cables: passo 36, immagine 3 di 3
    • Use the point of a spudger to carefully pry up and disconnect the top-right loudspeaker's blue coaxial cable from the motherboard.
    • Repeat this process for the white coaxial cable.
  37. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Unfasten the motherboard: passo 37, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Unfasten the motherboard: passo 37, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the three 2 mm screws securing the motherboard to the frame.
  38. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the motherboard: passo 38, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the motherboard: passo 38, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the motherboard: passo 38, immagine 3 di 3
    • Insert a spudger into a gap between the motherboard and the frame.
    • Pry up with the spudger to release the motherboard from its clips.
    • Remove the motherboard.
    • During reassembly, refasten the motherboard screws first to properly align it into place, then reconnect the cables.
  39. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Heat the left edge: passo 39, immagine 1 di 1
    • The top-left loudspeaker's connector is secured to the frame by adhesive; use heat to avoid tearing the connector.
    • Apply a heated iOpener to the left edge of the device for two minutes.
  40. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the loudspeaker cable's adhesive: passo 40, immagine 1 di 2 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the loudspeaker cable's adhesive: passo 40, immagine 2 di 2
    • Insert an opening pick between the loudspeaker cable and the frame.
    • Slice the adhesive while prying up with the pick to separate the cable from the frame.
  41. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the loudspeaker: passo 41, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the loudspeaker: passo 41, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the loudspeaker: passo 41, immagine 3 di 3
    • Use a spudger to pry up and separate the loudspeaker from the frame.
    • Remove the loudspeaker.
  42. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Heat the rear camera: passo 42, immagine 1 di 1
    • The rear camera is secured to the frame by adhesive; use heat to avoid damaging the camera.
    • Apply a heated iOpener to the top-left corner of the device for two minutes.
  43. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the rear camera's adhesive: passo 43, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the rear camera's adhesive: passo 43, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Separate the rear camera's adhesive: passo 43, immagine 3 di 3
    • Insert an opening pick into a gap between the rear camera and the frame.
    • Rotate the pick around edges of the rear camera to slice the adhesive.
  44. Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the rear camera: passo 44, immagine 1 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the rear camera: passo 44, immagine 2 di 3 Samsung Galaxy Tab S7 Plus Rear Camera Replacement, Remove the rear camera: passo 44, immagine 3 di 3
    • Pry up with the pick to separate the rear camera from the frame.
    • Remove the rear camera.
Conclusione
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
163.618 Reputazione
769 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.631 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 319
