Samsung Galaxy Tab S2 9.7 SM-T813 Motherboard Replacement
Introduzione
Vai al passo 1Replacement of the motherboard requires removal of a few other components first. See the prerequisite guides before attempting just the motherboard.
Cosa ti serve
Heat the iOpeners in a microwave for 1-2 minutes.
Place heated iOpeners on screen edges to heat the adhesive.
Place suctioning device near the corner of the screen and gently lift up to create a gap between the front panel assembly and the back.
Insert the picks to hold the two components apart once a gap is created.
Where can i get one of these screens for the best price. My mother is a retired senior and happened to drop sumthng on her tablet. I wld like to have it repaired as she just bought it for her xmas present a cple months ago. Now we see a new screen is around 300 $ but does anyone know if other screens from older samsung tablets that are also 9.7 “ will work or whr is cheapest place to find one ?
Remove the 17 silver 3.0 mm Phillips head screws located around the edge of the device using the screwdriver.
Using the screwdriver, remove the 4 black 3.0 mm Phillips head screws located on the upper and lower motherboard.
Altre 9 persone hanno completato questa guida.
2 Commenti
Very understandable, thank you very much! From the Philippines!
Do not remove the screen if you’re replacing the battery, much easier to heat up and pry off the back. Plus no chance of damaging your screen.
Joseph Watson - Replica
