Salta al contenuto principale
Samsung Galaxy Note9 Front Sensor Array Replacement
Cosa ti serve
  1. Samsung Galaxy Note9 Front Sensor Array Replacement, Eject the SIM card tray: passo 1, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Eject the SIM card tray: passo 1, immagine 2 di 2
    • Insert a SIM card eject tool straight into the hole in the SIM card tray.
    • Press to eject the SIM card tray.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the SIM card tray: passo 2, immagine 1 di 1
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Galaxy Note9 Front Sensor Array Replacement, Apply a heated iOpener: passo 3, immagine 1 di 1
    • Power off your phone before beginning disassembly.
    • Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Galaxy Note9 Front Sensor Array Replacement, Insert an opening pick: passo 4, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Insert an opening pick: passo 4, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Insert an opening pick: passo 4, immagine 3 di 3
    • Apply a suction handle to the back cover.
    • Lift with a suction handle to create a gap between the back cover and the frame of the phone.
    • Insert an opening pick into the gap.
    • If the glass is badly cracked, cover it in packing tape to create a surface for the suction cup to adhere to.
    • If the adhesive won't budge, apply more heat, not excessive force. Too much force could break the glass.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Galaxy Note9 Front Sensor Array Replacement, Cut through the adhesive: passo 5, immagine 1 di 1
    • Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
    • Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
    • If, at any point, the adhesive feels stubborn, apply more heat—not more force.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Galaxy Note9 Front Sensor Array Replacement, Slide the opening pick: passo 6, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Slide the opening pick: passo 6, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Slide the opening pick: passo 6, immagine 3 di 3
    • Starting from the center, cut the adhesive up and down the right side with an opening pick.
    • Do not insert the pick more than halfway into the phone when cutting near the fingerprint sensor or cameras, or you risk damaging internal components.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 7, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 7, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 7, immagine 3 di 3
    • Be careful near the corner, as the glass is very weak. Apply more heat at any time if the adhesive becomes stuck.
    • Leave an opening pick in the upper-right corner.
    • Use another opening pick to cut the adhesive around the bottom-right corner.
    • Leave that opening pick in the phone.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 8, immagine 1 di 1
    • Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 9, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 9, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 9, immagine 3 di 3
    • Be careful near the corners, as the glass is weakest there.
    • Insert an opening pick into the lower-left corner of the rear panel.
    • Using another opening pick, cut the adhesive along the left edge of the rear panel.
    • Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
    • It is fine if opening picks fall out as the back cover becomes separated.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 10, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 10, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 10, immagine 3 di 3
    • Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
    • Finally, cut the last of the adhesive along the top of the phone.
    • Use an iOpener, hair dryer, or heat gun to apply more heat as needed where you are cutting the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 11, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 11, immagine 2 di 2
    • Separate the right side of the rear cover first.
    • Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
    • Do not pull out the fingerprint sensor ribbon cable yet.
    • The fingerprint sensor cover might stay attached to the midframe.
    Chiedi a FixBot
    Aggiungi Commento
  12. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the fingerprint sensor: passo 12, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the fingerprint sensor: passo 12, immagine 2 di 2
    • Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
    Chiedi a FixBot
    Aggiungi Commento
  13. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 13, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Remove the back cover.
    • To re-install the back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
    • Turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
    Chiedi a FixBot
    Aggiungi Commento
  14. Attenzione: i passaggi 14-17 provengono da una guida contrassegnata come in corso.
    Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the upper midframe: passo 14, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the upper midframe: passo 14, immagine 2 di 2
    • Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
    Chiedi a FixBot
    Aggiungi Commento
  15. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 15, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 15, immagine 2 di 2
    • Insert the tip of a spudger into the upper-left corner of the upper midframe.
    • Pry the upper midframe out of the phone.
    • The upper midframe snaps into and out of place.
    Chiedi a FixBot
    Aggiungi Commento
  16. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 16, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 16, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 16, immagine 3 di 3
    • Peel the wireless charging coil off the battery starting with the left side.
    • The adhesive is weak but you can use an opening pick to cut it if necessary.
    • During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
    Chiedi a FixBot
    Aggiungi Commento
  17. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the battery: passo 17, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the battery: passo 17, immagine 2 di 2
    • Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  18. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the midframe: passo 18, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the midframe: passo 18, immagine 2 di 2
    • Remove the nine 4 mm Phillips screws from the plastic cover next to the battery.
    Chiedi a FixBot
    Aggiungi Commento
  19. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 19, immagine 1 di 1
    • Remove the plastic cover next to the battery.
    Chiedi a FixBot
    Aggiungi Commento
  20. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 20, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 20, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 20, immagine 3 di 3
    • Insert the tip of a spudger into the top of the lower midframe.
    • Pry the lower midframe out from the phone.
    • The lower midframe snaps into and out of place.
    • Remove the lower midframe.
    Chiedi a FixBot
    Aggiungi Commento
  21. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front camera: passo 21, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front camera: passo 21, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front camera: passo 21, immagine 3 di 3
    • Use the tip of a spudger to pry the front camera connector straight up and out of its socket.
    • Use tweezers to remove the front camera.
    Chiedi a FixBot
    Aggiungi Commento
  22. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the iris scanner: passo 22, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the iris scanner: passo 22, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the iris scanner: passo 22, immagine 3 di 3
    • Use the tip of a spudger to disconnect the iris scanner from the motherboard.
    • Use tweezers to remove the iris scanner.
    Chiedi a FixBot
    Aggiungi Commento
  23. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the front sensor array: passo 23, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the front sensor array: passo 23, immagine 2 di 2
    • Use the flat end of a spudger to pry the front sensor connector out of its socket.
    Chiedi a FixBot
    Aggiungi Commento
  24. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the display assembly: passo 24, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the display assembly: passo 24, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the display cable from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  25. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 25, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 25, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the touchscreen cable from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  26. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the charging assembly: passo 26, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the charging assembly: passo 26, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the charging assembly from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  27. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 27, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 27, immagine 2 di 2
    • Remove the three 4 mm Phillips screws securing the motherboard.
    • There are triangles next to the holes indicating the motherboard screw locations.
    Chiedi a FixBot
    Aggiungi Commento
  28. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 28, immagine 1 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 28, immagine 2 di 3 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 28, immagine 3 di 3
    • Use a spudger to gently lift the motherbord from the upper-left corner.
    • Carefully remove the motherboard.
    • Move the ribbon cables out of the way as necessary. Do not pull the motherboard out if it becomes snagged on any cables.
    Chiedi a FixBot
    Aggiungi Commento
  29. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front sensor array: passo 29, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front sensor array: passo 29, immagine 2 di 2
    • Use a pair of tweezers to peel back the adhesive-backed copper foil.
    • Stop peeling once you reach the sensor array.
    • Be careful not to tear the foil.
    Chiedi a FixBot
    Aggiungi Commento
  30. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 30, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 30, immagine 2 di 2
    • Use the tip of a spudger to lift the left side of the front sensor array and separate the adhesive the rest of the way.
    • The front sensor array is still connected to a ribbon cable that is adhered to the phone. Do not try to remove the front sensor array yet or you will damage it.
    Chiedi a FixBot
    Aggiungi Commento
  31. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 31, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 31, immagine 2 di 2
    • Carefully slide an opening pick under the front sensor array ribbon cable to cut the adhesive underneath.
    Chiedi a FixBot
    Aggiungi Commento
  32. Samsung Galaxy Note9 Front Sensor Array Replacement: passo 32, immagine 1 di 2 Samsung Galaxy Note9 Front Sensor Array Replacement: passo 32, immagine 2 di 2
    • Use a pair of tweezers to remove the front sensor array.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Sam Omiotek
Membro da: 02/25/19
99.430 Reputazione
290 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 44
Tutti i Tempi: 1,691
