Salta al contenuto principale
Samsung Galaxy Note 5 Back Cover Replacement
Sophia
Sophia e 6 altri collaboratori
Ultimo aggiornamento il May 21, 2018
10 - 30 minuti
Moderato
Guida fornita dalla comunità
Introduzione Migliore
Panoramica Video
  1. Samsung Galaxy Note 5 Back Cover Replacement, Samsung Galaxy Note 5 Back Cover Replacement: passo 1, immagine 1 di 1
    • Heat the back cover to melt the strong adhesive sticker underneath.
  2. Samsung Galaxy Note 5 Back Cover Replacement: passo 2, immagine 1 di 1
    • Try to pull and open a gap between back cover and frame after heat. Insert into a guitar pick to cut the sticker.
    Is it possible to pull it without breaking it?? :/
    Mohammad - Replica
  3. Samsung Galaxy Note 5 Back Cover Replacement: passo 3, immagine 1 di 1
    • If you do it hardly, you need much more heat especially the edged side.
    • Slipping a playing card through the gap is a good way to loosen up the adhesive.
  4. Samsung Galaxy Note 5 Back Cover Replacement: passo 4, immagine 1 di 1
    • Remove the back cover. The white stripe is the sticker.
Conclusione
Altre 45 persone hanno completato questa guida.
Sophia
Membro da: 03/25/14
43.861 Reputazione
62 Guide realizzate
9 Commenti
What about putting the one back on?
rcf917 - Replica
will it go back on and stay on without new adhesive?
dfasdfjiun - Replica
I suggest that you take new adhesive, old adhesive is not strong enough to hold back cover.
Witrigs -
You can check this video of put it back battery cover : https://www.youtube.com/watch?v=3HrmeVGY...
Witrigs - Replica
How do I remove the sticky part
Marcelino Lopez - Replica
How to put the cover back will there be a sticker in battery cover. And from where I will get to buy that
BIJLI R - Replica
Where do you find the replacement back for sale? I looked on the Samsung site, and no luck.
Marty Meyer - Replica
Hey I know its old but amazon has some back covers
Francisco Vazquez -
Anyone have a problem with one that is bricked won't charge and won't turn on but yet a wireless charger appear to be giving it a charge as light goes solid on charger when it is in contact what should I do this phone looks in great shape almost new condition
Johnathon Patterson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 35
Tutti i Tempi: 108,997
