Salta al contenuto principale
Samsung Epix LCD Display Replacement
Mark Wyse
Mark Wyse e 8 altri collaboratori
Ultimo aggiornamento il 5 lug 2023
Nessuna stima
Moderato
Pallini!
Introduzione Migliore
Dettagli Mancanti
Introduzione
Vai al passo 1
This guide shows you how to access the LCD display inside your phone.
Cosa ti serve
Strumenti
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Mostra di più…
  1. Samsung Epix LCD Display Replacement, Battery: passo 1, immagine 1 di 1
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
  2. Samsung Epix LCD Display Replacement: passo 2, immagine 1 di 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
  3. Samsung Epix LCD Display Replacement, LCD Display: passo 3, immagine 1 di 1
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
  4. Samsung Epix LCD Display Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
  5. Samsung Epix LCD Display Replacement: passo 5, immagine 1 di 2 Samsung Epix LCD Display Replacement: passo 5, immagine 2 di 2
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix LCD Display Replacement: passo 6, immagine 1 di 1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
  7. Samsung Epix LCD Display Replacement: passo 7, immagine 1 di 1
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
  8. Samsung Epix LCD Display Replacement: passo 8, immagine 1 di 1
    • Remove the front faceplate by lifting it off of the phone chassis.
  9. Samsung Epix LCD Display Replacement: passo 9, immagine 1 di 1
    • Using the opening tool, unlatch the LCD ribbon cable.
  10. Samsung Epix LCD Display Replacement: passo 10, immagine 1 di 1
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
  11. Samsung Epix LCD Display Replacement: passo 11, immagine 1 di 1
    • Lift the LCD display out from phone chassis.
Conclusione
Preparati per le riparazioni future
Acquista tutti
Mark Wyse
Membro da: 04/19/11
62 Reputazione
2 Guide realizzate
Cal Poly, Team 15-15, Regan Spring 2011 Membro di Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,964
