Salta al contenuto principale
Roller Blade Washer Replacement
Humza Khan
Humza Khan e 2 altri collaboratori
Ultimo aggiornamento il April 19, 2023
9 - 25 minuti
Facile
Tagliatore di Passi
Introduzione Migliore
Introduzione
Vai al passo 1
To do this replacement you need to make sure you have the correct size allen wrench and the washer fits properly because each roller blade has different specifications. If you do not put the washer on correctly it could cause the wheels to not spin as freely as they should. This fix is neccesary because if the washer is warped the wheels wont spin well or at all causing the front wheel to lock up.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Roller Blade Washer Replacement, Washer: passo 1, immagine 1 di 1
    • The roller blade needs to be side down on a flat surface
  2. Roller Blade Washer Replacement: passo 2, immagine 1 di 1
    • Use an Allen Wrench to unscrew the screws on each side of the wheel.
  3. Roller Blade Washer Replacement: passo 3, immagine 1 di 1
    • Remove the screws and wheel from the blade.
  4. Roller Blade Washer Replacement: passo 4, immagine 1 di 1
    • Take the old plastic washer off the long screw.
  5. Roller Blade Washer Replacement: passo 5, immagine 1 di 1
    • Retrieve the new plastic washer and insert between the blades on the inner side. Do the same to the other side, so that both sides have new plastic washers
  6. Roller Blade Washer Replacement: passo 6, immagine 1 di 1
    • Replace the wheel without dislodging the new plastic washers and center the hole of the wheel in each plastic washer.
  7. Roller Blade Washer Replacement: passo 7, immagine 1 di 1
    • Reinsert the screws through the plastic washers and wheel.
  8. Roller Blade Washer Replacement: passo 8, immagine 1 di 1
    • Lastly, tighten the screws with the Allen Wrench.
Conclusione
You just finished replacing the plastic washers, you can now go out and skate to your hearts content
3Commenti sulla guida
ভিঢা বাজার অগ্রণী ব্যাংকের
হাসিবুর রহমান - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,530
