Salta al contenuto principale
RetroMini Miyoo Mini Plus Battery Replacement
Cosa ti serve
  1. RetroMini Miyoo Mini Plus Battery Replacement, Battery: passo 1, immagine 1 di 2 RetroMini Miyoo Mini Plus Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Lay the device face down on a flat surface.
    • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
    Chiedi a FixBot
    Aggiungi Commento
  2. RetroMini Miyoo Mini Plus Battery Replacement: passo 2, immagine 1 di 2 RetroMini Miyoo Mini Plus Battery Replacement: passo 2, immagine 2 di 2
    • Use your fingernail to push in the battery compartment tab.
    • Lift the cover up to expose the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. RetroMini Miyoo Mini Plus Battery Replacement: passo 3, immagine 1 di 1
    • Use an opening tool to gently lift the the battery from its compartment.
    • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
    Chiedi a FixBot
    Aggiungi Commento
  4. RetroMini Miyoo Mini Plus Battery Replacement: passo 4, immagine 1 di 2 RetroMini Miyoo Mini Plus Battery Replacement: passo 4, immagine 2 di 2
    • Pinch the white battery connector and pull it directly out of its socket.
    • Completely remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. RetroMini Miyoo Mini Plus Battery Replacement: passo 5, immagine 1 di 2 RetroMini Miyoo Mini Plus Battery Replacement: passo 5, immagine 2 di 2
    • When you have the new battery, put the new battery wire into the connecter.
    • Place the battery back into the empty space with the wire at the bottom of the battery.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
1Commento della guida
Does anyone know where to get these batteries? Or perhaps the specs of the Miyoo Mini Plus battery such as dimensions (mine is a bit obese right now) and connector type?
Arend Hamming - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 86
Ultimi 30 giorni: 320
Tutti i Tempi: 2,475
