Salta al contenuto principale
Resealing Procedure
Resealing Procedure
Dominik Schnabelrauch
Dominik Schnabelrauch e 2 altri collaboratori
Ultimo aggiornamento il 3 nov 2023
5 - 10 minuti
Moderato
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Introduzione
Vai al passo 1
Use this guide to close and reseal your Apple Watch Series 4 after disassembly.
Cosa ti serve
Strumenti
  1. Resealing Procedure, Resealing Procedure: passo 1, immagine 1 di 1
    • Remove the blue protective film from the adhesive.
    • To simplify the removal you can lift and cut the blue protective film at one point. Avoid cutting the force touch gasket.
  2. Resealing Procedure: passo 2, immagine 1 di 3 Resealing Procedure: passo 2, immagine 2 di 3 Resealing Procedure: passo 2, immagine 3 di 3
    • Align the screen and press it down firmly onto the adhesive.
    • For best results, apply heat from your iOpener, heat gun, or hair dryer to help set the adhesive.
    • After the screen sits in place apply some pressure for a few hours by wrapping the watch with a couple rubber bands, or placing it under a heavy book or two.
    With the removal of force touch as a feature on the Apple Watch, is the final step of this process still applicable? It would be a pity of the removal of this feature causes somebody to think that failed in their repair attempt and disposed of their otherwise functional watch.
    Jim McCorison - Replica
    Is the adhesive strip just as good as say, B-7000 flexible glue for waterproofing?
    Bryan Williams - Replica
    Is the adhesive included with the replacement battery, I can not find it in the shop. Also, the step before removing the blue protective film, there must be a step how to apply the tape on the watch, or is that self evident?
    Ulfe - Replica
    I bought the iFixit batteri and also the adhesive strip, managed to get it all assembled in the end. In my opinion the hardest part of the whole process is to seat the adhesive. It’s all incredibly small, I would recommend a stationary magnifying glass with lamp. After carefully scraping off the old adhesive from the Force Touch sensor (was intact and glued to screen), I positioned the tape with tweezers onto watch body, gradually positioning it on each corner at a time. It’s not done in one go, I spent probably 15-20min to make it fit as evenly as I could. Feels like it requires the steady hands of a heart surgeon.
    Hopefully it’s now watertight, Fingers crossed.
    William Kempton - Replica
Conclusione
Altre 12 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
iFixit Membro di iFixit
Staff
119 Membri
21.724 Guide realizzate
2Commenti sulla guida
Ist der Kasten dann auch, zumindest theoretisch, wasserdicht?
Angelika Reichert - Replica
Ja. An den kritischen Stellen - Öffnungen für Mikro, Lautsprecher, Digital Crown, Druckknopf - wurde ja nichts gemacht.
Christian Guhl -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 171
Ultimi 30 Giorni: 564
Tutti i Tempi: 18,192
