Salta al contenuto principale
Replacing Spring in Refrigerator Door
Christine Meyers
Christine Meyers e 3 altri collaboratori
Ultimo aggiornamento il 29 gen 2024
20 minuti
Facile
Introduzione
Vai al passo 1
This guide shows the process for replacing a broken spring in a Kenmore Elite refrigerator door. Many brands are assembled similarly, specifically LG models, so this guide can help repair many refrigerator doors. All you will need for this fix is a Phillips screwdriver and a very small flat head, which any small size should work. Be sure to purchase the correct spring with the correct number of coils per your refrigerator. In this case, we are using a 6 coil spring. The process is very simple and rather short. Taking your time should run about 20 minutes and save you a good amount of money.
Cosa ti serve
Strumenti
  1. Replacing Spring in Refrigerator Door, Spring: passo 1, immagine 1 di 1
    • Turn off the refrigerator by unplugging it or turning the breaker off.
    • There are electrical cords attaching the assembly flap to the door, so it is better to be safe.
  2. Replacing Spring in Refrigerator Door: passo 2, immagine 1 di 2 Replacing Spring in Refrigerator Door: passo 2, immagine 2 di 2
    • With a Phillips screwdriver, unscrew and remove the two screws on the hinge located directly in the middle of the door, connecting the assembly flap to the door.
  3. Replacing Spring in Refrigerator Door: passo 3, immagine 1 di 2 Replacing Spring in Refrigerator Door: passo 3, immagine 2 di 2
    • Located at the bottom of the assembly flap, remove the bottom plastic piece by gently shimmying it out with a small flat head screwdriver.
    • This may be a bit difficult.
  4. Replacing Spring in Refrigerator Door: passo 4, immagine 1 di 2 Replacing Spring in Refrigerator Door: passo 4, immagine 2 di 2
    • Carefully lift the assembly flap upward guiding it along the top and bottom plastic hinge just before it comes off.
  5. Replacing Spring in Refrigerator Door: passo 5, immagine 1 di 3 Replacing Spring in Refrigerator Door: passo 5, immagine 2 di 3 Replacing Spring in Refrigerator Door: passo 5, immagine 3 di 3
    • On the bottom of the assembly flap, carefully insert the spring into the plastic holes. One is connected to the bottom plastic hinge and the other is attached to the assembly flap.
    • Slide the assembly flap down into place. Be sure the top and bottom plastic hinge slides into place. You’ll notice the spring securely sliding into the plastic holes.
  6. Replacing Spring in Refrigerator Door: passo 6, immagine 1 di 2 Replacing Spring in Refrigerator Door: passo 6, immagine 2 di 2
    • Re-insert the bottom plastic piece by pressing it in until it snaps.
  7. Replacing Spring in Refrigerator Door: passo 7, immagine 1 di 3 Replacing Spring in Refrigerator Door: passo 7, immagine 2 di 3 Replacing Spring in Refrigerator Door: passo 7, immagine 3 di 3
    • Replace the two screws on the middle, metal hinge.
    • Turn the power on. Fast Fix is complete.
Conclusione
Altre 4 persone hanno completato questa guida.
1Commento della guida
Very helpful! Easily completed and solved my problem.
Stephen Joncus - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 145
Tutti i Tempi: 14,622
