Repairing a Tear in a Tent
Introduzione
Vai al passo 1Even a small tear can grow into a big problem when you are out in the wild and exposed to the elements. Fortunately, repairing a tear is simple. A few stitches can have your tent, or just about anything else with a tear, ship-shape in no time.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Thread your needle and tie a knot in the end.
Drive the needle from the back of the material, just before where the tear starts.
Pull the thread taut.
One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
Ensure that the stitches are tight, and cut any excess threads.
Instead of cutting the excess thread, I leave enough length at the end to “bury” the long threads inside the repair, where they will not show and are less likely to loosen up.
We use a clear repair patch kind of tape to fix our tents called fixmytear repair tape. So much cheaper than paying a machinist to fix it. Apply it to both sides if you can for extra strength.
1Commento della guida
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
