Salta al contenuto principale
Repairing a Tear in a Tent
Brittany McCrigler
Brittany McCrigler e 3 altri collaboratori
Ultimo aggiornamento il 16 mag 2023
5 - 10 minuti
Facile
Patagonia
Introduzione
Vai al passo 1
Even a small tear can grow into a big problem when you are out in the wild and exposed to the elements. Fortunately, repairing a tear is simple. A few stitches can have your tent, or just about anything else with a tear, ship-shape in no time.
  1. Repairing a Tear in a Tent, Sew a Ladder Stitch: passo 1, immagine 1 di 3 Repairing a Tear in a Tent, Sew a Ladder Stitch: passo 1, immagine 2 di 3 Repairing a Tear in a Tent, Sew a Ladder Stitch: passo 1, immagine 3 di 3
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Repairing a Tear in a Tent: passo 2, immagine 1 di 2 Repairing a Tear in a Tent: passo 2, immagine 2 di 2
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Repairing a Tear in a Tent: passo 3, immagine 1 di 2 Repairing a Tear in a Tent: passo 3, immagine 2 di 2
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Repairing a Tear in a Tent: passo 4, immagine 1 di 2 Repairing a Tear in a Tent: passo 4, immagine 2 di 2
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Repairing a Tear in a Tent: passo 5, immagine 1 di 3 Repairing a Tear in a Tent: passo 5, immagine 2 di 3 Repairing a Tear in a Tent: passo 5, immagine 3 di 3
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
    Instead of cutting the excess thread, I leave enough length at the end to “bury” the long threads inside the repair, where they will not show and are less likely to loosen up.
    Kathleen Slamka - Replica
    We use a clear repair patch kind of tape to fix our tents called fixmytear repair tape. So much cheaper than paying a machinist to fix it. Apply it to both sides if you can for extra strength.
    https://www.amazon.com/Fixmytear-Magic-R...
    https://www.amazon.com/fixmytear-Magic-R...
    W731620 E - Replica
Linea Traguardo
Brittany McCrigler
Membro da: 03/05/12
90.014 Reputazione
142 Guide realizzate
iFixit Membro di iFixit
Staff
121 Membri
20.489 Guide realizzate
1Commento della guida
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
bobhunter50023 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 208
Tutti i Tempi: 10,451
