Salta al contenuto principale
RazorX DLX Electric Skateboard Trucks Replacement
Emmett Normand
Emmett Normand e 3 altri collaboratori
Ultimo aggiornamento il December 30, 2024
10 minuti
Moderato
Introduzione
Vai al passo 1
This guide is intended to show you how to replace the trucks on a RazorX DLX Electric Skateboard. This guide can be used for other standard skateboards as well. The trucks on a skateboard connect the board to the wheels and also house the bushings. Having damaged trucks can make the skateboard unsafe to use. Before you start, make sure the power button is switched to off.
  1. RazorX DLX Electric Skateboard Trucks Replacement, Wheel and Bearing: passo 1, immagine 1 di 3 RazorX DLX Electric Skateboard Trucks Replacement, Wheel and Bearing: passo 1, immagine 2 di 3 RazorX DLX Electric Skateboard Trucks Replacement, Wheel and Bearing: passo 1, immagine 3 di 3
    • Flip the skateboard onto its side.
    • Use a 13 mm socket wrench to remove the nut that holds the wheel onto the trucks.
    • Pull the wheel off.
    • There will be a small washer between the nut and the bearing; make sure you don't lose it.
  2. RazorX DLX Electric Skateboard Trucks Replacement: passo 2, immagine 1 di 3 RazorX DLX Electric Skateboard Trucks Replacement: passo 2, immagine 2 di 3 RazorX DLX Electric Skateboard Trucks Replacement: passo 2, immagine 3 di 3
    • Set the nut and washers aside.
    • Remove the bearings and spacer by pushing/prying them out against the trucks.
    • Place the tip of the truck into the bearing, firmly grip the wheel, push down and rotate outward to remove each bearing. Keep track of the spacer that is in between the bearings during removal.
  3. RazorX DLX Electric Skateboard Trucks Replacement: passo 3, immagine 1 di 2 RazorX DLX Electric Skateboard Trucks Replacement: passo 3, immagine 2 di 2
    • Insert one bearing into your replacement wheel.
    • Place the spacer centered onto that bearing and insert the second bearing on top of it.
    • The bearings should fit snugly in place.
  4. RazorX DLX Electric Skateboard Trucks Replacement: passo 4, immagine 1 di 2 RazorX DLX Electric Skateboard Trucks Replacement: passo 4, immagine 2 di 2
    • See the first photo for the order of reassembly.
    • Place one washer onto the trucks first.
    • Place the wheel with your bearings in place onto the trucks, with the face of the wheel outward.
    • Place the next washer on the trucks.
    • Place the nut on the trucks, and tighten using a 13mm socket wrench.
    • Do not over tighten the nut. The wheel should spin freely and smoothly.
  5. RazorX DLX Electric Skateboard Trucks Replacement, Trucks: passo 5, immagine 1 di 3 RazorX DLX Electric Skateboard Trucks Replacement, Trucks: passo 5, immagine 2 di 3 RazorX DLX Electric Skateboard Trucks Replacement, Trucks: passo 5, immagine 3 di 3
    • Orient the skateboard so that you have access to the four 32 mm bolts and the nuts that hold them in place,
    • Remove the four 32 mm bolts with a 3 mm Allen key while holding the nut in place.
  6. RazorX DLX Electric Skateboard Trucks Replacement: passo 6, immagine 1 di 2 RazorX DLX Electric Skateboard Trucks Replacement: passo 6, immagine 2 di 2
    • Pull the trucks off.
    • When reassembling the board, do not forget the black riser.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Cuesta, Team 20-4, Krynen Fall 2024 Membro di Cuesta, Team 20-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G4
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 37
