Salta al contenuto principale
Raspberry Pi 3 SD Card Replacement
ΛΛKΛRΞT
ΛΛKΛRΞT e 2 altri collaboratori
Ultimo aggiornamento il 4 ott 2024
35 secondi - 5 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
In this guide I will show you how to change SD card in your Raspberry Pi 3.
Cosa ti serve
  1. Raspberry Pi 3 SD Card Replacement, Raspberry Pi 3 SD Card replacement.: passo 1, immagine 1 di 1
    • The Raspberry Pi 3 should look like this closed.
  2. Raspberry Pi 3 SD Card Replacement, Top cover removal: passo 2, immagine 1 di 1
    • Open the top lid like I have done on the image.
    • The top is marked that you are gonna remove in the next step.
  3. Raspberry Pi 3 SD Card Replacement, Cover for GPIO Hider and IO Shield removal: passo 3, immagine 1 di 1
    • Now remove the cover for the two covers.
    • It should look like the image.
    • I have marked the covers for the next step.
  4. Raspberry Pi 3 SD Card Replacement, IO Shield and GPIO Hider removal: passo 4, immagine 1 di 1
    • Remove the two sides.
  5. Raspberry Pi 3 SD Card Replacement, Removal.: passo 5, immagine 1 di 2 Raspberry Pi 3 SD Card Replacement, Removal.: passo 5, immagine 2 di 2
    • Now we should successfully have removed the case.
    • Notice that the side shown on the first image is the one that we are intrested in.
    • When we have flipped the Pi 3 over we can remove the SD card.
    if you follow this you may brake the sd card of the raspberry pi here is a updated guide
    step 1 flip the raspberry pi over
    step 2 remove the sd card
    step 3 put new sd card in
    step 4 flip the raspberry pi back over
    done
    Kieran jones - Replica
Conclusione
Altre 5 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
ΛΛKΛRΞT
Membro da: 11/22/17
229 Reputazione
1 Guida realizzata
1Commento della guida
On the official RPi case there’s a cutout where the SD card inserts. This is a pointless guide to be honest.
Stephen Wilson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,327
