Salta al contenuto principale
ROG Strix G15 G512LI M.2 SSD Replacement
June
June e 4 altri collaboratori
Ultimo aggiornamento il 26 lug 2023
10 - 20 minuti
Moderato
Guida fornita dalla comunità
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. ROG Strix G15 G512LI M.2 SSD Replacement, Removing The Cover: passo 1, immagine 1 di 1
    • Remove the screws from the compartment cover, As show in the diagram, unscrew the screws labeled "A" first. before unscrewing "B", Don't remove screw "B" from the cover.
    I have a problem taking the bottom cover off, based on the diagram shown the top right of the cover will not come off, i tried lifting it up but it seems like its gonna break.
    Galaxy NoahPlayz - Replica
    Turned out that the screw wouldn’t let that corner out, however it ended up costing the cover to be broken, i kept unscrewing it and nothing, i think something was wrong with the structure of the screw itself, i cant get it out though.
    Galaxy NoahPlayz -
  2. ROG Strix G15 G512LI M.2 SSD Replacement: passo 2, immagine 1 di 1
    • Remove the panel, but be careful as there are 2 cables linking the RGB light bar to the motherboard, carefully and gently detach them from the motherboard and lift the panel.
    How do you remove the panel!? It looks like it will break. (Honestly have no idea why there are clips securing the bottom on this. They have ELEVEN screws in it! It ain't gonna move, not even for a 200lb gorilla like me lol
    Nicholas Royer - Replica
    Nevermind. Got it open, but was scared of breaking something.
    The side vents (intakes or exhaust, not sure) have two clips each, so you need the little blue triangles to wedge in there and pop them loose.
    Nicholas Royer -
  3. ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: passo 3, immagine 1 di 2 ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: passo 3, immagine 2 di 2
    • Locate the M.2 SSD slots, the First and Third slots both support SATA and PCIe NVMe M.2 SSDs, and the second M.2 Slot only supports PCIe NVMe SSDs
    • Next, Insert the NVMe SSD, and screw the SSD into place with the retaining screws
Conclusione
Preparati per le riparazioni future
Acquista tutti
June
Membro da: 09/28/21
590 Reputazione
3 Guide realizzate
2Commenti sulla guida
how to fix the light bar i have one side wont light on
fethallah - Replica
are the m.2 nvme slot PCIe 3.0x4 and are they all the same speed or type?
Yousef Suwaidan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 80
Tutti i Tempi: 8,197
