Salta al contenuto principale
Protocol Videodrone AP Battery Wiring  Replacement
Serge
Serge e 5 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
15 - 20 minuti
Difficile
Necessarie Immagini Migliori
Tagliatore di Passi
Introduzione
Vai al passo 1
This guide will show you how to replace the battery and the soldering new wires to the motherboard. This is guide includes a highly recommend soldering guide. CAUTION: Soldering iron will be hot and may cause minor burns if handles improperly.
Cosa ti serve
Strumenti
  1. Protocol Videodrone AP Battery Wiring  Replacement, Battery Wiring: passo 1, immagine 1 di 1
    • Make sure the drone is turned off
  2. Protocol Videodrone AP Battery Wiring  Replacement: passo 2, immagine 1 di 1
    • Open the hatch and carefully pull out the battery to expose the cable connection
  3. Protocol Videodrone AP Battery Wiring  Replacement: passo 3, immagine 1 di 2 Protocol Videodrone AP Battery Wiring  Replacement: passo 3, immagine 2 di 2
    • Carefully pull apart the cable connection
  4. Protocol Videodrone AP Battery Wiring  Replacement: passo 4, immagine 1 di 2 Protocol Videodrone AP Battery Wiring  Replacement: passo 4, immagine 2 di 2
    • Unscrew the 4 screws from the bottom of the drone.
    • Unscrew the 8 screws connecting the propeller guards to the drone
    • Unscrew the four propeller screws.
    • One screw is hidden behind the screwdriver.
  5. Protocol Videodrone AP Battery Wiring  Replacement: passo 5, immagine 1 di 1
    • Carefully remove faulty battery wiring from the drone
  6. Protocol Videodrone AP Battery Wiring  Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Feed through opening using tweezers to grasp the wire and carefully pull through.
  7. Protocol Videodrone AP Battery Wiring  Replacement: passo 7, immagine 1 di 1
    • Use the soldering iron to solder new wires to mother board. CAUTION: Soldering iron may get hot and cause minor burns if handled improperly.
    • Use this guide for how to solder: https://www.youtube.com/watch?v=QKbJxytE...
  8. Protocol Videodrone AP Battery Wiring  Replacement: passo 8, immagine 1 di 1
    • Reattach the battery and test for power by turning on the drone and look for the 4 LEDs turn on.
Conclusione
All Done!
Preparati per le riparazioni future
Acquista tutti
Serge
Membro da: 09/26/17
340 Reputazione
3 Guide realizzate
USF Tampa, Team S2-G1, Passmore Fall 2017 Membro di USF Tampa, Team S2-G1, Passmore Fall 2017
USFT-PASSMORE-F17S2G1
4 Membri
3 Guide realizzate
3Commenti sulla guida
Great explanation. Just wondering where to get the replacement piece. My drone has the black wire hanging by a single strand just outside the white connector. The red wire is in tact but I would need the whole part that attaches to the board and extends outside the drone to connect the battery to. Thanks
yasureok - Replica
Was wondering i think its charging the blue light flashes when plugged in but wont turn on. Wires look brand new
Michael Landry - Replica
I’m wondering the same thing, mine lights up blue when charging, wires look good but still no action.
Ryann Hunter -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,919
