Salta al contenuto principale
Problem with navigation in the Android System Recovery menu
ZFix
ZFix e 2 altri collaboratori
Ultimo aggiornamento il 20 apr 2021
2 - 5 minuti
Molto facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
When you try to do a Factory reset through the Android system recovery menu, you can't navigate normally. This is common problem with Samsung Galaxy Tab 3 7.0. The light cursor is moved only if you press the Volume button twice - then it will move through two menus.
Where is the problem?
When you press Up or Down once, it does actually change the selection, but the system doesn't refresh the screen.
Here's the solution:
Panoramica Video
  1. Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: passo 1, immagine 1 di 3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: passo 1, immagine 2 di 3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: passo 1, immagine 3 di 3
    • Open the Android System Recovery menu.
    • You can find the manual how to do this here.
    • If your tablet is stuck on the Android robot with exclamation mark picture, press the Volume Up or Down button.
    • Now, if the cursor is on "reboot system now", press the Volume Down key twice to go to "apply update from external storage", and just once to go to "wipe data...".
    • The cursor will stay on "apply update..." but the real selection will be "wipe data / factory reset".
    • Press the Power On button to select it. In the next menu you must choose "Yes - erase all user data".
    • Use the same technique to choose it. And finally, "reboot system now".
  2. Problem with navigation in the Android System Recovery menu: passo 2, immagine 1 di 2 Problem with navigation in the Android System Recovery menu: passo 2, immagine 2 di 2
    • If the cursor is on "Apply update from ADB", press the Volume Down key twice to go to "wipe data/factory reset" and choose it with the Power On button.
    • On the next screen press press the Volume Down 3x to go steb before "Yes --delete all user data".
    • Press another one time the Volume down button. The cursor will not move, but actually you are on the "Yes -- delete all user data" and you can select it with the Power On button.
    • Did you do it successfully?
Conclusione
Altre 36 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
ZFix
Membro da: 12/09/13
195.060 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
327 Membri
1.429 Guide realizzate
13Commenti sulla guida
When i factory reset through the Android system recovery menu, i can't navigate normally.
I fix it now,thank you very much!
AndroidDataRecovery - Replica
Fix all data. System
Macky Villanueva -
I can't do it it just does up with a different thing
irirangihammond - Replica
Wow I did not know this.ill try this way and thanks for the benifit
issammax147 - Replica
I got to the page where I gave to select yes but it jumps 2 spaces up and down and jumps past the yes option. How can I do it
Brittany - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 46
Tutti i Tempi: 74,934
