Salta al contenuto principale
PowerShot G7 X Mark II LCD Screen Replacement
Brandon
Brandon e 4 altri collaboratori
Ultimo aggiornamento il 10 giu 2024
10 - 15 minuti
Facile
Foto Azione
Necessarie Più Immagini
Introduzione
Vai al passo 1
This guide will show how to replace the LCD screen on the camera. This replacement is useful if the LCD screen has been cracked or has stopped working.
Cosa ti serve
Strumenti
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: passo 2, immagine 1 di 1
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: passo 3, immagine 1 di 1
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
    there's a small square of glue gum near the middle 4mm screw (from step 2). It holds the black plastic part and the LCD screen together. You can see the square gum on step 4 photo.
    You'll have to pull a bit (gently) to detach the screen.
    oluc - Replica
  4. PowerShot G7 X Mark II LCD Screen Replacement: passo 4, immagine 1 di 1
    • The screen is detached and can now be replaced.
    Do the replacement screens keep the touchscreen functionality of the camera? Do you know of any good sources to buy the replacement screen from?
    Steve Beecheno - Replica
Conclusione
Altre 5 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Brandon
Membro da: 02/15/17
644 Reputazione
4 Guide realizzate
USF Tampa, Team 12-3, Eyestone Spring 2017 Membro di USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 Membri
4 Guide realizzate
5Commenti sulla guida
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - Replica
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - Replica
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - Replica
on ebay or amazon. you can order it
nicole -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 152
Tutti i Tempi: 10,476
