Salta al contenuto principale
PowerA Enhanced Wireless Controller Directional Pad Replacement
Ayjah Montgomery
Ayjah Montgomery e 4 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
15 - 30 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show you how to access and replace the directional pad of your PowerA Enhanced Wireless Controller. Built-up residue can cause complications with the directional pad. As this cannot always be cleaned away with a Q-tip and rubbing alcohol, it may be necessary to disassemble the controller to either clean beneath the directional pad or change it entirely. Follow the steps provided to do so.
Cosa ti serve
Strumenti
Mostra di più…
  1. PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: passo 1, immagine 1 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: passo 1, immagine 2 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: passo 1, immagine 3 di 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 2, immagine 1 di 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 3, immagine 1 di 2 PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 3, immagine 2 di 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 4, immagine 1 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 4, immagine 2 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement: passo 4, immagine 3 di 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: passo 5, immagine 1 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: passo 5, immagine 2 di 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use the rubber tweezers to grab the center of the directional pad and pull it out by pinching its center.
Conclusione
Preparati per le riparazioni future
Acquista tutti
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro di USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membri
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,162
