Salta al contenuto principale
Power Mac G5 RAM Replacement
Salvador Aguilar
Salvador Aguilar e 6 altri collaboratori
Ultimo aggiornamento il 11 giu 2023
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
Use this guide to replace/upgrade the RAM in your Power Mac G5.
  1. Power Mac G5 RAM Replacement, Side Panel: passo 1, immagine 1 di 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 RAM Replacement: passo 2, immagine 1 di 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 RAM Replacement: passo 3, immagine 1 di 2 Power Mac G5 RAM Replacement: passo 3, immagine 2 di 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 RAM Replacement: passo 4, immagine 1 di 3 Power Mac G5 RAM Replacement: passo 4, immagine 2 di 3 Power Mac G5 RAM Replacement: passo 4, immagine 3 di 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 RAM Replacement, Front Fan Assembly: passo 5, immagine 1 di 1
    • Locate the front fan assembly.
  6. Power Mac G5 RAM Replacement: passo 6, immagine 1 di 1
    • Pull the fan assembly out; it should slide out easily.
  7. Power Mac G5 RAM Replacement, RAM: passo 7, immagine 1 di 1
    • Locate the RAM on the Power Mac G5.
  8. Power Mac G5 RAM Replacement: passo 8, immagine 1 di 3 Power Mac G5 RAM Replacement: passo 8, immagine 2 di 3 Power Mac G5 RAM Replacement: passo 8, immagine 3 di 3
    • Use your thumbs to push the RAM ejector pins to the sides.
    • The RAM module should pop up slightly.
  9. Power Mac G5 RAM Replacement: passo 9, immagine 1 di 1
    • Remove the RAM module from the DIMM slot.
    • The RAM modules must be installed in pairs, with one module per bank (top and bottom).
    • When reinstalling the RAM, make sure to note the notch on the DIMM slot. This notch needs to line up with the corresponding gap on the RAM module.
    When installing new memory, note the orientation of the notch in the row of pins - about two fifths from the front of the computer - in relation to the matching ridge in the slots.
    edgroupinc - Replica
    You must be sure that the locking levers at each end of each module is engaged securely. Test by gently pulling on each corner of the modules.
    I would recommend re-seating the existing modules several times before buying new ones. Worked for me.
    Alan Fahrenbruch - Replica
Conclusione
Altre 61 persone hanno completato questa guida.
Cal Poly, Team 5-8, Forte Winter 2010 Membro di Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Membri
20 Guide realizzate
2Commenti sulla guida
Major thing to note, you must install RAM in pairs. You can't just install one card on the top and not one on the bottom. Pairs start from the center and move outwards.
Red Rabbit 90 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 60
Tutti i Tempi: 41,169
