Salta al contenuto principale
Polaroid Flash Unit Shell Replacement
Cosa ti serve
  1. Polaroid Flash Unit Shell Replacement, Before you begin: passo 1, immagine 1 di 1
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Unplug all cables from your camera.
  2. Polaroid Flash Unit Shell Replacement, Open your camera: passo 2, immagine 1 di 2 Polaroid Flash Unit Shell Replacement, Open your camera: passo 2, immagine 2 di 2
    • Fully open the flash unit at the front of your camera.
  3. Polaroid Flash Unit Shell Replacement, Remove the screw cover: passo 3, immagine 1 di 3 Polaroid Flash Unit Shell Replacement, Remove the screw cover: passo 3, immagine 2 di 3 Polaroid Flash Unit Shell Replacement, Remove the screw cover: passo 3, immagine 3 di 3
    • Slide the tip of an opening pick under the right edge of the screw cover, near the flash.
    • Leave the pick inserted under the cover for the next step.
  4. Polaroid Flash Unit Shell Replacement: passo 4, immagine 1 di 3 Polaroid Flash Unit Shell Replacement: passo 4, immagine 2 di 3 Polaroid Flash Unit Shell Replacement: passo 4, immagine 3 di 3
    • Slide the cover towards the flash to release the clips securing it.
    • Your pick might fall out—that's fine.
    • Pull the cover straight away from the camera and remove it.
  5. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: passo 5, immagine 1 di 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: passo 5, immagine 2 di 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: passo 5, immagine 3 di 3
    • Hold the flash unit open with one hand.
    • With your free hand, use a Phillips screwdriver to remove the three 5.9 mm‑long screws securing the flash unit shell.
  6. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: passo 6, immagine 1 di 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: passo 6, immagine 2 di 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: passo 6, immagine 3 di 3
    • Fully close the flash unit for a better grip on the shell.
    • Secure the camera with one hand, and firmly grip the flash unit shell with the other.
    • Lift the right edge of the shell (the side closest to the charging port) to release the clips securing it.
    • You should feel and hear "clicks" as the clips release.
    • Pull the shell up and away from the camera to remove it.
    • During reassembly, put the shell in place and push down firmly to engage the clips.
Conclusione
Spencer Day
Membro da: 09/14/22
149.442 Reputazione
995 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.618 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 182
