Polaroid Automatic 100 Bottom Frame Spring Replacement
Introduzione
Vai al passo 1The spring is located within a slender metal mount that is screwed into the front underside of the Polaroid. It is below the camera lens and can be seen through the mount it is within.
Cosa ti serve
Fully extend the bellows to prevent collapse using the #1 tab.
Altre 2 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti2Commenti sulla guida
Thank you so very much!!!
You saved my camera and my sanity!!!!
