Philips Norelco MultiGroom 3100 Motor Replacement
Introduzione
Vai al passo 1This guide will teach you how to replace the motor and will require some soldering.
Cosa ti serve
Strumenti
Mostra di più…
Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use the tweezers to pull out the inner power button.
Altre 4 persone hanno completato questa guida.
4 Commenti
¿Me puedes ayudar con algo?
Can you help me with something?
this guide was created also by nina lovekrist in 2015
Where can I get the motor with copper shaft?
