Philips HD9252 Transformer Replacement
Introduzione
Vai al passo 1Follow this guide for instructions on how to remove and replace the air fryer's transformer. Removal of the transformer may be required if the device is being taken to another country where power outlets are different from the United States.
Cosa ti serve
Strumenti
Mostra di più…
Insert a nylon spudger underneath the top of the device.
Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
Remove the top by lifting it upwards and setting it down.
Hi, I cannot lift the top half because it's blocked by the exhaust vent. Any step that I am missing?
Remove the two 39.5 mm screws attached to the black piece of the transformer using a JIS #1 screwdriver.
1Commento della guida
This is not the transformer, it is the coil of the shaded-pole motor.
