Introduzione
Note::: taking apart your device may void the warranty on the device, please proceed with caution and consider having it sent in first if possible to be worked on by the company. This guide's goal is to help the user to replace the battery of a PS Vita Slim. In case the battery is faulty or has some other kind of problem.
Cosa ti serve
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
Using the spudger carefully pry the battery out of the socket. Do not remove the battery fully yet.
Now using the tweezers carefully remove the ribbon connecting the battery from the hardware.
Altre 8 persone hanno completato questa guida.
Un commento
Whilst tearing down my PCH-2016 model PS Vita Slim I have noticed that there is also a screw in the cartridge area that needs to be removed to remove the back panel.
