Outer Shell Disassembly
Introduzione
Vai al passo 1The process of removing covers and simple internal components requires minimal technical experience.
Cosa ti serve
Unplug the device from any energy sources.
Lift the top cover of the scanner.
Use a plastic opening tool to remove the plastic frame surrounding the glass.
To reassemble, simply follow the steps in reverse order.
Altre 8 persone hanno completato questa guida.
1Commento della guida
Excellent helpful easy to follow instructions. Thanks.
In step 7, removal of the Touch Pad, I was not able to locate the release clip. Feeling around, what I thought was the latch was a ribbon cable that I distorted but didn't destroy. The top came off without the Touch Pad removal. Once the top was off, I located a latch on the back right of the Touch Pad, but once released, it didn't help to free up the Touch Pad. I couldn't get the Touch Pad off.
