Salta al contenuto principale
Optoma PRO360W Bulb Replacement
Desiree Benitez
Desiree Benitez e 3 altri collaboratori
Ultimo aggiornamento il January 27, 2025
8 minuti
Facile
Inconveniente Markup
Tagliatore di Passi
Introduzione
Vai al passo 1
This guide will provide a step-by-step process on how to safely remove and replace a light bulb for an Optoma PRO360W projector. In the process of this removal, we will demonstrate how to clean the area of any dust and how to recycle the waste material- the old light bulb.
Cosa ti serve
Strumenti
  1. Optoma PRO360W Bulb Replacement, Unplug projector: passo 1, immagine 1 di 1
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Optoma PRO360W Bulb Replacement: passo 2, immagine 1 di 1
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Optoma PRO360W Bulb Replacement: passo 3, immagine 1 di 1
    • Unscrew the bulb screws on either side of the silver plate.
  4. Optoma PRO360W Bulb Replacement: passo 4, immagine 1 di 1
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Optoma PRO360W Bulb Replacement: passo 5, immagine 1 di 1
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Optoma PRO360W Bulb Replacement: passo 6, immagine 1 di 1
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Optoma PRO360W Bulb Replacement: passo 7, immagine 1 di 1
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Optoma PRO360W Bulb Replacement: passo 8, immagine 1 di 1
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Optoma PRO360W Bulb Replacement: passo 9, immagine 1 di 1
    • Dispose of the bulb by sending it to a recycling center.
Conclusione
Desiree Benitez
Membro da: 01/21/17
128 Reputazione
1 Guida realizzata
1Commento della guida
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 855
