Salta al contenuto principale
OnePlus 9 5G Screen Replacement
Cosa ti serve
  1. OnePlus 9 5G Screen Replacement, Eject the SIM card tray: passo 1, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Eject the SIM card tray: passo 1, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Eject the SIM card tray: passo 1, immagine 3 di 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press firmly to eject the tray.
    Chiedi a FixBot
    Aggiungi Commento
  2. OnePlus 9 5G Screen Replacement, Remove the SIM card tray: passo 2, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Remove the SIM card tray: passo 2, immagine 2 di 2
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
    Chiedi a FixBot
    Aggiungi Commento
  3. OnePlus 9 5G Screen Replacement, Loosen the rear glass: passo 3, immagine 1 di 1
    • Completely power off your phone before you begin.
    • Prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  4. OnePlus 9 5G Screen Replacement, Insert an opening pick: passo 4, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Insert an opening pick: passo 4, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Insert an opening pick: passo 4, immagine 3 di 3
    • Apply a suction handle to the rear glass, as close to the bottom edge as possible.
    • If your rear glass is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the broken rear glass.
    • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
    Chiedi a FixBot
    Aggiungi Commento
  5. OnePlus 9 5G Screen Replacement, Slice the bottom edge adhesive: passo 5, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Slice the bottom edge adhesive: passo 5, immagine 2 di 2
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  6. OnePlus 9 5G Screen Replacement, Insert a second opening pick: passo 6, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Insert a second opening pick: passo 6, immagine 2 di 2
    • Insert a second opening pick underneath the bottom edge of the rear glass.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  7. OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: passo 7, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: passo 7, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: passo 7, immagine 3 di 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  8. OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: passo 8, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: passo 8, immagine 2 di 2
    • Insert a fourth opening pick underneath the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  9. OnePlus 9 5G Screen Replacement, Slice the right edge adhesive: passo 9, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Slice the right edge adhesive: passo 9, immagine 2 di 2
    • Insert a fifth and final opening pick underneath the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  10. OnePlus 9 5G Screen Replacement, Remove the rear glass: passo 10, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Remove the rear glass: passo 10, immagine 2 di 2
    • Remove the rear glass.
    • If the rear glass is still stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    Chiedi a FixBot
    Aggiungi Commento
  11. OnePlus 9 5G Screen Replacement, Peel off the tape: passo 11, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Peel off the tape: passo 11, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Peel off the tape: passo 11, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Use a pair of tweezers to carefully peel the bottom right corner of the charging coil tape off of the daughterboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  12. OnePlus 9 5G Screen Replacement: passo 12, immagine 1 di 2 OnePlus 9 5G Screen Replacement: passo 12, immagine 2 di 2
    • Use a pair of tweezers to carefully peel the bottom left corner of the charging coil tape off of the loudspeaker.
    Chiedi a FixBot
    Aggiungi Commento
  13. OnePlus 9 5G Screen Replacement, Pry up the flash assembly: passo 13, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Pry up the flash assembly: passo 13, immagine 2 di 2
    • The flash assembly is held in place by mild adhesive and covers a motherboard cover screw.
    • Carefully slide an opening pick underneath the bottom edge of the flash assembly.
    • Use your opening pick to pry up the flash assembly.
    • Don't try to remove the flash assembly all the way during this procedure. Its cable is adhered to the backside of the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  14. OnePlus 9 5G Screen Replacement, Unfasten the motherboard cover: passo 14, immagine 1 di 1
    • Use a Phillips screwdriver to remove the ten 3.8 mm-long screws securing the motherboard cover.
    • One of the motherboard cover screws is covered by a white water ingress sticker. To unfasten the screw you can puncture the sticker with your screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  15. OnePlus 9 5G Screen Replacement, Pry up the motherboard cover: passo 15, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Pry up the motherboard cover: passo 15, immagine 2 di 2
    • The motherboard cover is further held in place by tight plastic clips.
    • Insert a spudger underneath the bottom right edge of the motherboard cover.
    • Pry upwards to loosen the motherboard cover and create a gap.
    Chiedi a FixBot
    Aggiungi Commento
  16. OnePlus 9 5G Screen Replacement: passo 16, immagine 1 di 3 OnePlus 9 5G Screen Replacement: passo 16, immagine 2 di 3 OnePlus 9 5G Screen Replacement: passo 16, immagine 3 di 3
    • Insert an opening pick underneath the bottom right edge of the motherboard cover.
    • Slide the opening pick up along the right edge of the motherboard cover.
    • Twist the opening pick to release the plastic clips and pry up the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  17. OnePlus 9 5G Screen Replacement, Remove the motherboard cover: passo 17, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Remove the motherboard cover: passo 17, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
    • The charging coil is attached to the motherboard cover and will lift up at the same time.
    Chiedi a FixBot
    Aggiungi Commento
  18. OnePlus 9 5G Screen Replacement, Disconnect the battery cable: passo 18, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Disconnect the battery cable: passo 18, immagine 2 di 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Chiedi a FixBot
    Aggiungi Commento
  19. OnePlus 9 5G Screen Replacement, Unfasten the daughterboard cover: passo 19, immagine 1 di 1
    • Use a Phillips screwdriver to remove the five 3.8 mm-long screws securing the daugtherboard cover.
    • One of the daughterboard cover screws is covered by a white water ingress sticker. To unfasten the screw you can puncture the sticker with your screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  20. OnePlus 9 5G Screen Replacement, Pry up the daughterboard cover: passo 20, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Pry up the daughterboard cover: passo 20, immagine 2 di 2
    • Insert the point of a spudger underneath the top right edge of the daughterboard cover.
    • Pry upwards to loosen the daughterboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  21. OnePlus 9 5G Screen Replacement, Remove the daughterboard cover: passo 21, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Remove the daughterboard cover: passo 21, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the daughterboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  22. OnePlus 9 5G Screen Replacement, Disconnect the interconnect cable: passo 22, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Disconnect the interconnect cable: passo 22, immagine 2 di 2
    • Use a spudger to disconnect the interconnect cable from the motherboard by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  23. OnePlus 9 5G Screen Replacement, Remove the metal bracket: passo 23, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Remove the metal bracket: passo 23, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Remove the metal bracket: passo 23, immagine 3 di 3
    • Slide one arm of a pair of tweezers underneath the metal bracket covering the interconnect cable.
    • Use your tweezers to lift and unhinge the metal bracket.
    • Remove the metal bracket.
    Chiedi a FixBot
    Aggiungi Commento
  24. OnePlus 9 5G Screen Replacement, Disconnect the interconnect cable: passo 24, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Disconnect the interconnect cable: passo 24, immagine 2 di 2
    • Use a spudger to disconnect the interconnect cable from the daughterboard by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  25. OnePlus 9 5G Screen Replacement, Remove the interconnect cable: passo 25, immagine 1 di 1
    • Use a pair of tweezers or your fingers to remove the interconnect cable.
    Chiedi a FixBot
    Aggiungi Commento
  26. OnePlus 9 5G Screen Replacement, Disconnect the antenna board and fingerprint cables: passo 26, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Disconnect the antenna board and fingerprint cables: passo 26, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Disconnect the antenna board and fingerprint cables: passo 26, immagine 3 di 3
    • Use a spudger to disconnect the antenna board cable and the fingerprints sensor from the daughterboard by prying the connectors straight up from their sockets.
    Chiedi a FixBot
    Aggiungi Commento
  27. OnePlus 9 5G Screen Replacement, Disconnect the black coaxial cable: passo 27, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Disconnect the black coaxial cable: passo 27, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Disconnect the black coaxial cable: passo 27, immagine 3 di 3
    • Slide one arm of a pair of tweezers under the black antenna cable until it‘s snug against the metal connector.
    • Disconnect the antenna cable by prying the connector straight up from the daughterboard.
    Chiedi a FixBot
    Aggiungi Commento
  28. OnePlus 9 5G Screen Replacement, Disconnect the white coaxial cable: passo 28, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Disconnect the white coaxial cable: passo 28, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Disconnect the white coaxial cable: passo 28, immagine 3 di 3
    • Slide one arm of a pair of tweezers under the white antenna cable until it‘s snug against the metal connector.
    Chiedi a FixBot
    Aggiungi Commento
  29. OnePlus 9 5G Screen Replacement, Unfasten the daughterboard: passo 29, immagine 1 di 1
    • Use a Phillips driver to remove the 2.8 mm-long screw securing the daughterboard.
    Chiedi a FixBot
    Aggiungi Commento
  30. OnePlus 9 5G Screen Replacement, Pry up the daughterboard: passo 30, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Pry up the daughterboard: passo 30, immagine 2 di 2
    • Insert the point of a spudger underneath the top right corner of the daughterboard.
    • Pry upwards to loosen the daughterboard.
    Chiedi a FixBot
    Aggiungi Commento
  31. OnePlus 9 5G Screen Replacement, Remove the daughterboard: passo 31, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Remove the daughterboard: passo 31, immagine 2 di 2
    • Use a pair of blunt nose tweezers or your fingers to remove the daughterboard.
    • Before reinserting the daughterboard, make sure all cables that connect to it are out of the way.
    Chiedi a FixBot
    Aggiungi Commento
  32. OnePlus 9 5G Screen Replacement, Disconnect the display: passo 32, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Disconnect the display: passo 32, immagine 2 di 2
    • Use a spudger to disconnect the display cable by prying the connector straight up from its socket on the bottom right corner.
    Chiedi a FixBot
    Aggiungi Commento
  33. OnePlus 9 5G Screen Replacement, Loosen the display adhesive: passo 33, immagine 1 di 1
    • Apply a heated iOpener to the screen for 3 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to touch.
    Chiedi a FixBot
    Aggiungi Commento
  34. OnePlus 9 5G Screen Replacement, Insert an iFlex: passo 34, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Insert an iFlex: passo 34, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Insert an iFlex: passo 34, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force and insert an iFlex between the screen and frame.
    • Make sure to insert the iFlex underneath the screen and not the plastic frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    Chiedi a FixBot
    Aggiungi Commento
  35. OnePlus 9 5G Screen Replacement, Insert an opening pick: passo 35, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Insert an opening pick: passo 35, immagine 2 di 2
    • Insert an opening pick between the iFlex and the screen.
    • Remove the iFlex.
    Chiedi a FixBot
    Aggiungi Commento
  36. OnePlus 9 5G Screen Replacement, Slice the bottom edge adhesive: passo 36, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Slice the bottom edge adhesive: passo 36, immagine 2 di 2
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  37. OnePlus 9 5G Screen Replacement: passo 37, immagine 1 di 2 OnePlus 9 5G Screen Replacement: passo 37, immagine 2 di 2
    • Insert a second opening pick at the bottom right corner and slide it to the bottom left corner of the screen to slice the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  38. OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: passo 38, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: passo 38, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Slice the left edge adhesive: passo 38, immagine 3 di 3
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • When slicing near the front facing camera, only insert the opening pick 2.5 mm to avoid damaging it.
    Chiedi a FixBot
    Aggiungi Commento
  39. OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: passo 39, immagine 1 di 3 OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: passo 39, immagine 2 di 3 OnePlus 9 5G Screen Replacement, Slice the top edge adhesive: passo 39, immagine 3 di 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1–2 minutes to reheat it.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  40. OnePlus 9 5G Screen Replacement, Slice the right edge adhesive: passo 40, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Slice the right edge adhesive: passo 40, immagine 2 di 2
    • Insert a fifth opening pick underneath the top right corner of the screen and slide it along the right edge of the phone to slice the remaining adhesive.
    • Don't try to remove the display all the way yet, the display cable is still threaded through the midframe.
    Chiedi a FixBot
    Aggiungi Commento
  41. OnePlus 9 5G Screen Replacement, Free the display cable: passo 41, immagine 1 di 2 OnePlus 9 5G Screen Replacement, Free the display cable: passo 41, immagine 2 di 2
    • Flip the phone over.
    • Lift the bottom edge of the phone and carefully thread the display cable through its gap in the frame.
    Chiedi a FixBot
    Aggiungi Commento
  42. OnePlus 9 5G Screen Replacement, Remove the screen: passo 42, immagine 1 di 1
    • Remove the screen.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our OnePlus 9 5G answers community for help.
Altre 3 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
122 Membri
25.946 guide realizzate
1Commento della guida
how closely can I follow this guide for a Oneplus 9 Pro?
Hunter Chen - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 43
Ultimi 30 giorni: 220
Tutti i Tempi: 13,825
