Salta al contenuto principale
OnePlus 6 Motherboard Replacement
John Steven Trammell
John Steven Trammell e 3 altri collaboratori
Ultimo aggiornamento il December 28, 2021
40 - 45 minuti
Moderato
Foto Azione
Introduzione
Vai al passo 1
If your OnePlus 6 is powering on but is not displaying anything on the screen, will not turn on at all after fully charging, or is otherwise malfunctioning, use this guide to replace the motherboard.
The motherboard is the main communication center for all the hardware to the processor in the phone. Without a properly functioning motherboard, the phone’s components will be out of sequence with each other causing performance malfunctions such as glitches and loss of power.
Before attempting to replace the motherboard of the OnePlus 6, check out the troubleshooting page for the device to see if other solutions are available. Sometimes a connector being loose to the motherboard or faulty battery can cause glitching and power loss. If none of these solutions solve the problem, this guide will show you how to replace the motherboard.
The first step of this guide requires you to remove the back panel of the phone, which is made of glass, so be careful during removal not to shatter it.
Be sure to back up your phone to prevent memory loss if you are able to. Also, before completing this replacement guide, make sure to shut down the phone and to disconnect any outside sources.
Cosa ti serve
Strumenti
Mostra di più…
  1. OnePlus 6 Motherboard Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
    I used half a razor blade here
    derhagen - Replica
    If you have a glass back cover, be careful not to pull too much or it may crack. It's better if you keep heating the area before trying to get in with the opening picks, specially around the corners.
    tottimeatter - Replica
    I was using a hairdryer on 2/3 heat level and my phone was very hot to the touch and it still wouldn't budge a millimeter to get the plastic tools in. Any advice? I'm not sure heating it more is safe for the rest of the phone, so I'm not sure what else to do.
    Tim Harry - Replica
  2. OnePlus 6 Motherboard Replacement: passo 2, immagine 1 di 2 OnePlus 6 Motherboard Replacement: passo 2, immagine 2 di 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    Signal problem
    Ravi dhiman - Replica
  3. OnePlus 6 Motherboard Replacement: passo 3, immagine 1 di 2 OnePlus 6 Motherboard Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Motherboard Replacement, Battery: passo 4, immagine 1 di 2 OnePlus 6 Motherboard Replacement, Battery: passo 4, immagine 2 di 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
    If step 3 is followed, then the back panel is removed in step 4. First photo shows back panel still attached.
    nereocystis - Replica
  5. OnePlus 6 Motherboard Replacement, Fingerprint sensor: passo 5, immagine 1 di 2 OnePlus 6 Motherboard Replacement, Fingerprint sensor: passo 5, immagine 2 di 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
    ATTENTION - Be aware that the screw at the bottom left is marked wrong in this picture. The actual 10th screw is actually underneath the round white sticker. Do not remove the screw marked at bottom left, but strip over the white sticker which has a screw underneath it. Otherwise you will damage your midframe board.
    Jerome - Replica
    It is completely unnecessary to remove the plastic frame as shown in this step, the connector is already accessible.
  6. OnePlus 6 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
    You also need to remove the screw in the middle of the motherboard, next to the top camera, which is not mentioned.
    Jakub Wardyn - Replica
  7. OnePlus 6 Motherboard Replacement: passo 7, immagine 1 di 2 OnePlus 6 Motherboard Replacement: passo 7, immagine 2 di 2
    • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
    • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
    • The cameras should lift up with the motherboard.
    Don't forget to disconnect the earpiece and antenna wires.
Conclusione
Altre 6 persone hanno completato questa guida.
Clemson, Team 4-3, Hunter Fall 2021 Membro di Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Membri
14 Guide realizzate
1Commento della guida
Can you repair my One plus 6. It's one IC of motherboard is damaged.
AMIT PANWAR - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 70
Tutti i Tempi: 4,196
