Salta al contenuto principale
Olympus SP-320 Back casing and LCD screen Replacement
Brenna McCullough
Brenna McCullough e 2 altri collaboratori
Ultimo aggiornamento il 26 ago 2020
7 - 10 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show you how to take apart and replace your camera's back casing and LCD screen. When following guide steps be gentle with your camera because there are internal ribbons that can easily tear!
Cosa ti serve
Strumenti
Mostra di più…
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: passo 1, immagine 1 di 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: passo 1, immagine 2 di 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: passo 1, immagine 3 di 3
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: passo 2, immagine 1 di 1
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: passo 3, immagine 1 di 1
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: passo 4, immagine 1 di 3 Olympus SP-320 Back casing and LCD screen Replacement: passo 4, immagine 2 di 3 Olympus SP-320 Back casing and LCD screen Replacement: passo 4, immagine 3 di 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: passo 5, immagine 1 di 3 Olympus SP-320 Back casing and LCD screen Replacement: passo 5, immagine 2 di 3 Olympus SP-320 Back casing and LCD screen Replacement: passo 5, immagine 3 di 3
    • You have detached the back casing and LCD screen.
Conclusione
1Commento della guida
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 629
