Salta al contenuto principale
Nvidia Shield Tablet Rear Case Replacement
Molly Bauer
Molly Bauer e 5 altri collaboratori
Ultimo aggiornamento il 7 mar 2024
15 - 20 minuti
Moderato
Introduzione
Vai al passo 1
The case of any device is always the first line of defense against any kind of external damage. The Shield Tablet in particular is known to be susceptible to casing cracks, specifically at the corners. This guide will show you the step-by-step instructions required to replace your cracked case.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nvidia Shield Tablet Rear Case Replacement, Rear Case: passo 1, immagine 1 di 2 Nvidia Shield Tablet Rear Case Replacement, Rear Case: passo 1, immagine 2 di 2
    • First, remove the stylus from your tablet.
    Which website I can buy battery?
    Hang Chetha - Replica
  2. Nvidia Shield Tablet Rear Case Replacement: passo 2, immagine 1 di 3 Nvidia Shield Tablet Rear Case Replacement: passo 2, immagine 2 di 3 Nvidia Shield Tablet Rear Case Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Rear Case Replacement: passo 3, immagine 1 di 2 Nvidia Shield Tablet Rear Case Replacement: passo 3, immagine 2 di 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
Conclusione
Altre 5 persone hanno completato questa guida.
Molly Bauer
Membro da: 08/27/15
1.442 Reputazione
6 Guide realizzate
USF Tampa, Team 2-2, Blackwell Fall 2015 Membro di USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Membri
11 Guide realizzate
1Commento della guida
I snapped the cable of the dabbler on the rear case coz i didnt know there was one!
Anyone knows where can i get a new one?
damjannedelkovski - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,429
