Salta al contenuto principale
Nothing Phone (1) Screen Replacement
Cosa ti serve
  1. Nothing Phone (1) Screen Replacement, Heat the rear glass: passo 1, immagine 1 di 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nothing Phone (1) Screen Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • If you're having trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nothing Phone (1) Screen Replacement, Slice the adhesive: passo 3, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Slice the adhesive: passo 3, immagine 2 di 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nothing Phone (1) Screen Replacement, Slice the adhesive: passo 4, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Slice the adhesive: passo 4, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Slice the adhesive: passo 4, immagine 3 di 3
    • When you slice near the glyph, insert only the tip of the opening pick (~2-3 mm) to avoid damaging the LEDs.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nothing Phone (1) Screen Replacement: passo 5, immagine 1 di 2 Nothing Phone (1) Screen Replacement: passo 5, immagine 2 di 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nothing Phone (1) Screen Replacement: passo 6, immagine 1 di 2 Nothing Phone (1) Screen Replacement: passo 6, immagine 2 di 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • At this point, the rear glass should be separated from the frame. If there's still resistance around the edges of the glass, use an opening pick to separate any remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  7. Nothing Phone (1) Screen Replacement, Remove the rear glass: passo 7, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Remove the rear glass: passo 7, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Dust Blower
    $5.99
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Since the rear glass of the Nothing Phone (1) is transparent a dust blower may come in handy for cleaning before installing a new rear glass.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    Chiedi a FixBot
    Aggiungi Commento
  8. Nothing Phone (1) Screen Replacement, Remove the plastic cover: passo 8, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Remove the plastic cover: passo 8, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Remove the plastic cover: passo 8, immagine 3 di 3
    • The plastic covering the earpiece speaker is held in place by mild adhesive. If you're having a hard time removing it, apply a heated iOpener for 1-2 minutes to loosen the adhesive underneath.
    • Insert an opening pick underneath the grey plastic cover at the top edge of your phone.
    • Use your opening pick to pry up the plastic cover.
    • Remove the plastic cover.
    Chiedi a FixBot
    Aggiungi Commento
  9. Nothing Phone (1) Screen Replacement, Unfasten the earpiece speaker screws: passo 9, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the earpiece speaker.
    Chiedi a FixBot
    Aggiungi Commento
  10. Nothing Phone (1) Screen Replacement, Remove the earpiece speaker: passo 10, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Remove the earpiece speaker: passo 10, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Remove the earpiece speaker: passo 10, immagine 3 di 3
    • Insert the flat end of a spudger underneath the bottom edge of the earpiece speaker.
    • Use your spudger to pry up the earpiece speaker.
    • Use a pair of tweezers or your fingers to remove the earpiece speaker.
    Chiedi a FixBot
    Aggiungi Commento
  11. Nothing Phone (1) Screen Replacement, Disconnect the flash assembly LED glyph cables: passo 11, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Disconnect the flash assembly LED glyph cables: passo 11, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Disconnect the flash assembly LED glyph cables: passo 11, immagine 3 di 3
    • Use a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
    • Use a spudger to disconnect the LED glyph cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  12. Nothing Phone (1) Screen Replacement, Remove the recording indicator light cover: passo 12, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Remove the recording indicator light cover: passo 12, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Remove the recording indicator light cover: passo 12, immagine 3 di 3
    • Insert an opening pick underneath the recording indicator light cover at the top right corner of the screen.
    • Use a pair of tweezers or your fingers to remove the recording indicator light cover.
    Chiedi a FixBot
    Aggiungi Commento
  13. Nothing Phone (1) Screen Replacement, Remove the bottom LED glyph assembly: passo 13, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Remove the bottom LED glyph assembly: passo 13, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Remove the bottom LED glyph assembly: passo 13, immagine 3 di 3
    • Be very careful when working on the bottom LED assembly. There's a cable running underneath its whole surface that can be damaged easily.
    • The bottom LED assembly is held in place by small pieces of adhesive.
    • Slide an opening pick underneath the right, bottom and left edge of the bottom LED assembly to carefully separate it from the daughterboard cover.
    • Do not slide the opening pick deeper than shown in the photos. Otherwise you risk damaging the LED cable.
    Chiedi a FixBot
    Aggiungi Commento
  14. Nothing Phone (1) Screen Replacement, Fold over the bottom LED assembly: passo 14, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Fold over the bottom LED assembly: passo 14, immagine 2 di 2
    • The bottom LED assembly is still held in place by a small piece of adhesive sitting between the cable winds. Avoid straining or tearing the cable when folding the assembly over.
    • Use a pair of blunt nosed tweezers and carefully fold the bottom LED assembly over to get free access to the LED cable connector.
    Chiedi a FixBot
    Aggiungi Commento
  15. Nothing Phone (1) Screen Replacement, Open the connector bracket: passo 15, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Open the connector bracket: passo 15, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Open the connector bracket: passo 15, immagine 3 di 3
    • The LED connector bracket sits very tight and may require some force to open it.
    • Insert one arm of a pair of tweezers into the gap at the right side of the connector bracket.
    • Push your tweezers toward the left edge of the phone to free the closure flap of the connector bracket.
    • If you're struggling to free the flap, pull the black rubber piece to the left to give the bracket more room.
    • Lift the connector bracket with your tweezers to access the LED connector.
    Chiedi a FixBot
    Aggiungi Commento
  16. Nothing Phone (1) Screen Replacement, Disconnect the LED cable: passo 16, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Disconnect the LED cable: passo 16, immagine 2 di 2
    • Use a spudger to disconnect the LED cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  17. Nothing Phone (1) Screen Replacement, Remove the bottom LED assembly: passo 17, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Remove the bottom LED assembly: passo 17, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the bottom LED assembly.
    Chiedi a FixBot
    Aggiungi Commento
  18. Nothing Phone (1) Screen Replacement, Unfasten the daughterboard cover screws: passo 18, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the five 4.2 mm-long screws securing the daughterboard cover.
    • The center-most screw is covered by a white sticker.
    Chiedi a FixBot
    Aggiungi Commento
  19. Nothing Phone (1) Screen Replacement, Remove the plastic shield: passo 19, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Remove the plastic shield: passo 19, immagine 2 di 2
    • The grey plastic shield on top of the daughterboard cover is held in place by mild adhesive.
    • Use a pair of tweezers to carefully separate the grey plastic shield from the daughterboard cover and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  20. Nothing Phone (1) Screen Replacement, Fingerprint cable information: passo 20, immagine 1 di 1
    • When prying up the daughterboard cover in the following step be very careful and avoid levering with too much force or to press your prying tool too deep underneath the cover. Otherwise, the fingerprint cable running underneath can be easily torn.
    Chiedi a FixBot
    Aggiungi Commento
  21. Nothing Phone (1) Screen Replacement, Pry up the daughterboard cover: passo 21, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Pry up the daughterboard cover: passo 21, immagine 2 di 2
    • Insert the pointed end of a spudger underneath the top edge of the daughterboard cover just above the black rubber guard securing the LED connector bracket.
    • Pry up with the spudger to release the daughterboard cover from its clips.
    Chiedi a FixBot
    Aggiungi Commento
  22. Nothing Phone (1) Screen Replacement, Remove the daughterboard cover: passo 22, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Remove the daughterboard cover: passo 22, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the daughterboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  23. Nothing Phone (1) Screen Replacement, Remove the black rubber guard: passo 23, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Remove the black rubber guard: passo 23, immagine 2 di 2
    • Use a pair of tweezers to remove the black rubber guard securing the LED connector bracket.
    Chiedi a FixBot
    Aggiungi Commento
  24. Nothing Phone (1) Screen Replacement, Remove the connector bracket: passo 24, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Remove the connector bracket: passo 24, immagine 2 di 2
    • Use a pair of tweezers to remove the LED connector bracket.
    Chiedi a FixBot
    Aggiungi Commento
  25. Nothing Phone (1) Screen Replacement, Disconnect the interconnect cable: passo 25, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Disconnect the interconnect cable: passo 25, immagine 2 di 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  26. Nothing Phone (1) Screen Replacement, Separate the interconnect cable adhesive: passo 26, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Separate the interconnect cable adhesive: passo 26, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Separate the interconnect cable adhesive: passo 26, immagine 3 di 3
    • The interconnect cable is held in place by mild adhesive.
    • Carefully slide an opening pick underneath the interconnect cable to separate it from the charging coil assembly and the loudspeaker.
    Chiedi a FixBot
    Aggiungi Commento
  27. Nothing Phone (1) Screen Replacement, Fold over the interconnect cable: passo 27, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Fold over the interconnect cable: passo 27, immagine 2 di 2
    • During the following step do not fold the cable sharply and only bend it to avoid cable damage.
    • Use a pair of tweezers to fold the interconnect cable to the left like you'd open the cover of a book.
    Chiedi a FixBot
    Aggiungi Commento
  28. Nothing Phone (1) Screen Replacement, Unfasten the motherboard cover screws: passo 28, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the four 4.2 mm-long screws securing the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  29. Nothing Phone (1) Screen Replacement, Separate the wireless charging coil adhesive: passo 29, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Separate the wireless charging coil adhesive: passo 29, immagine 2 di 2
    • The charging coil assembly is held in place by mild adhesive.
    • Insert an opening pick underneath the bottom right edge of the charging coil assembly.
    • Slide the opening along the right edge of the charging coil assembly to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  30. Nothing Phone (1) Screen Replacement: passo 30, immagine 1 di 2 Nothing Phone (1) Screen Replacement: passo 30, immagine 2 di 2
    • Insert an opening pick underneath the bottom left edge of the charging coil assembly.
    • Slide the opening along the left edge of the charging coil assembly to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  31. Nothing Phone (1) Screen Replacement, Fold over the charging board assembly: passo 31, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Fold over the charging board assembly: passo 31, immagine 2 di 2
    • When folding the charging coil assembly over avoid straining components and cables.
    • Carefully fold the charging coil to the top edge of the phone to access the motherboard cover screws.
    Chiedi a FixBot
    Aggiungi Commento
  32. Nothing Phone (1) Screen Replacement, Unfasten the motherboard cover screws: passo 32, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three 4.2 mm-long screws securing the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  33. Nothing Phone (1) Screen Replacement, Separate the camera cover and flash assembly: passo 33, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Separate the camera cover and flash assembly: passo 33, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Separate the camera cover and flash assembly: passo 33, immagine 3 di 3
    • Return the charging coil to its original position.
    • Don't try to remove the camera cover and flash assembly all the way. Its cable runs underneath the motherboard cover and is very fragile.
    • Carefully slide an opening pick underneath the camera cover and flash assembly to separate it from the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  34. Nothing Phone (1) Screen Replacement, Fold over the camera cover and flash assembly: passo 34, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Fold over the camera cover and flash assembly: passo 34, immagine 2 di 2
    • Avoid straining the camera cover and flash assembly cable when folding it over.
    • Use a pair of tweezers to carefully fold the camera cover and flash assembly toward the battery.
    Chiedi a FixBot
    Aggiungi Commento
  35. Nothing Phone (1) Screen Replacement, Unfasten the motherboard cover screws: passo 35, immagine 1 di 1
    • Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the motherboard cover.
    • Return the camera cover and flash assembly to its original position.
    Chiedi a FixBot
    Aggiungi Commento
  36. Nothing Phone (1) Screen Replacement, Pry up the motherboard cover: passo 36, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Pry up the motherboard cover: passo 36, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Pry up the motherboard cover: passo 36, immagine 3 di 3
    • Carefully fold the charging coil to the top edge of the phone to access the bottom edge of the motherboard cover.
    • Insert the flat end of a spudger underneath the bottom right edge of the motherboard cover.
    • Pry up with the spudger to release the motherboard cover from its clips.
    • Repeat the prying procedure for the bottom left edge of the motherboard cover.
    Chiedi a FixBot
    Aggiungi Commento
  37. Nothing Phone (1) Screen Replacement, Remove the LED glyph assembly: passo 37, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Remove the LED glyph assembly: passo 37, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Remove the LED glyph assembly: passo 37, immagine 3 di 3
    • Remove the LED glyph assembly.
    Chiedi a FixBot
    Aggiungi Commento
  38. Nothing Phone (1) Screen Replacement, Disconnect the battery cable: passo 38, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Disconnect the battery cable: passo 38, immagine 2 di 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  39. Nothing Phone (1) Screen Replacement, Unfasten the loudspeaker screws: passo 39, immagine 1 di 1
    • Remove the two screws securing the loudspeaker:
    • One 4.2 mm-long Phillips screw
    • One 4.2 mm-long Torx T5 screw
    Chiedi a FixBot
    Aggiungi Commento
  40. Nothing Phone (1) Screen Replacement, Remove the loudspeaker: passo 40, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Remove the loudspeaker: passo 40, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Remove the loudspeaker: passo 40, immagine 3 di 3
    • Insert an spudger underneath the top edge of the loudspeaker.
    • Use your spudger to pry up the loudspeaker.
    • Use your fingers or a pair of tweezers to remove the loudspeaker.
    Chiedi a FixBot
    Aggiungi Commento
  41. Nothing Phone (1) Screen Replacement, Disconnect the fingerprint reader: passo 41, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Disconnect the fingerprint reader: passo 41, immagine 2 di 2
    • Use a spudger to disconnect the fingerprint reader cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  42. Nothing Phone (1) Screen Replacement, Disconnect the black antenna cable: passo 42, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Disconnect the black antenna cable: passo 42, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Disconnect the black antenna cable: passo 42, immagine 3 di 3
    • Slide a pair of tweezers under the black coaxial cable until they're snug against the metal connector.
    • Disconnect the black coaxial cable by prying it straight up from the daughterboard.
    • Use your tweezers to carefully loosen the cable from its routing on the daughterboard and bend it to the side.
    Chiedi a FixBot
    Aggiungi Commento
  43. Nothing Phone (1) Screen Replacement, Disconnect the white antenna cable: passo 43, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Disconnect the white antenna cable: passo 43, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Disconnect the white antenna cable: passo 43, immagine 3 di 3
    • Slide a pair of tweezers under the white coaxial cable until they're snug against the metal connector.
    • Disconnect the white coaxial cable by prying it straight up from the daughterboard.
    Chiedi a FixBot
    Aggiungi Commento
  44. Nothing Phone (1) Screen Replacement, Remove the SIM card tray: passo 44, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Remove the SIM card tray: passo 44, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Remove the SIM card tray: passo 44, immagine 3 di 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
    Chiedi a FixBot
    Aggiungi Commento
  45. Nothing Phone (1) Screen Replacement, Unfasten the daughterboard screw: passo 45, immagine 1 di 1
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw securing the daughterboard.
    Chiedi a FixBot
    Aggiungi Commento
  46. Nothing Phone (1) Screen Replacement, Remove the daughterboard: passo 46, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Remove the daughterboard: passo 46, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Remove the daughterboard: passo 46, immagine 3 di 3
    • Insert the pointed end of a spudger underneath the top edge of the daughterboard.
    • Use your spudger to pry up the daughterboard.
    • Use a pair of tweezers of your fingers to carefully remove the daughterboard.
    Chiedi a FixBot
    Aggiungi Commento
  47. Nothing Phone (1) Screen Replacement, Disconnect the display cable: passo 47, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Disconnect the display cable: passo 47, immagine 2 di 2
    • Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  48. Nothing Phone (1) Screen Replacement, Loosen the display adhesive: passo 48, immagine 1 di 1
    • During the display removal procedure, make sure all cables are placed underneath the phone and don't stick out to prevent damaging them.
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 5 minutes.
    • The display adhesive of the Nothing Phone (1) is strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Chiedi a FixBot
    Aggiungi Commento
  49. Nothing Phone (1) Screen Replacement, Insert an opening pick: passo 49, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Insert an opening pick: passo 49, immagine 2 di 2
    • Once the screen is warm to touch, apply a suction handle to the top edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the midframe and the screen, to the right side of the earpiece speaker cut-out.
    • Don't try to move this opening pick to the top right corner of the screen. There's a plastic pin on its rear side holding the display in position and blocking the way of the opening pick.
    Chiedi a FixBot
    Aggiungi Commento
  50. Nothing Phone (1) Screen Replacement, Slice the adhesive: passo 50, immagine 1 di 2 Nothing Phone (1) Screen Replacement, Slice the adhesive: passo 50, immagine 2 di 2
    • Insert a second opening pick at the left side of the earpiece speaker cut-out.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2-3 mm) to avoid damaging or smearing the camera.
    • Slide the opening pick along the top edge of the screen to slice the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  51. Nothing Phone (1) Screen Replacement: passo 51, immagine 1 di 3 Nothing Phone (1) Screen Replacement: passo 51, immagine 2 di 3 Nothing Phone (1) Screen Replacement: passo 51, immagine 3 di 3
    • Insert a third opening pick at the top left corner of the screen.
    • Slide the opening pick along the left edge of the phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  52. Nothing Phone (1) Screen Replacement: passo 52, immagine 1 di 2 Nothing Phone (1) Screen Replacement: passo 52, immagine 2 di 2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • Insert a fourth opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  53. Nothing Phone (1) Screen Replacement: passo 53, immagine 1 di 2 Nothing Phone (1) Screen Replacement: passo 53, immagine 2 di 2
    • Insert a fifth opening pick at the bottom right corner of the screen.
    • Slide the opening pick along the right edge to slice the remaining adhesive.
    • Do not try to remove the display all the way yet. The display cable is still threaded through the frame.
    Chiedi a FixBot
    Aggiungi Commento
  54. Nothing Phone (1) Screen Replacement, Remove the screen: passo 54, immagine 1 di 3 Nothing Phone (1) Screen Replacement, Remove the screen: passo 54, immagine 2 di 3 Nothing Phone (1) Screen Replacement, Remove the screen: passo 54, immagine 3 di 3
    • Carefully thread the display cable through the gap in the midframe.
    • Remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Altre 12 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
122 Membri
25.842 guide realizzate
10Commenti sulla guida
Hi. I recently had to disassemble my Nothing Phone. when reassembling it, I used a normal adhesive (T700). I noticed that the glass back isn't on the same level as the edge of aluminum frame. when I looked back at the original back adhesive, I noticed that it has some thickness to it (it has some cushion) which was keeping the glass back flush with the edge of the aluminum frame. I'm wondering if the Tesa 61395 Tape is similar to the original adhesive that the phone was sealed with? I just want to know before purchasing the tape you've listed above. Thanks in advance.
Muhammed Yaqoubi - Rispondi Condividi
Where to buy the LCD screen?
Saba - Rispondi Condividi
Hello, did you need to do any kind of parts pairing for the in-screen fingerprint scanner during the replacement process?
Jacob Mehnert - Rispondi Condividi
where did you get the screen?
Dev Ra - Rispondi Condividi
Where can you find the replacement screen?
Lourenço Vaz Pato - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 23
Ultimi 7 giorni: 114
Ultimi 30 giorni: 449
Tutti i Tempi: 31,536
