Nook Color Display Replacement
Introduzione
Vai al passo 1Use this guide to replace a cracked or malfunctioning display on your Nook Color tablet (identified by model number BNRV200).
The Nook Color uses an LG display made of two glass layers separated by a thin crystal layer. Your display may need to be replaced if it becomes cracked or the touchscreen no longer responds. The display could also experience "screen burn-in" which is when some of the pixels powering the display malfunction and cause uneven lighting and colors.
Before replacing the display, be sure to remove the device from any external power source and to completely shut down the device.
Cosa ti serve
Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
You might want to tell them that the little yellow ribbon has a little thing you have to lift to remove the ribbon from the mother board. I thought I killed it. The rest of your instructions are perfect. Thanks
Use a plastic opening tool to gently pry the display upwards.
Lift the display out with your hands until the display has separated from the frame.
Altre 6 persone hanno completato questa guida.
1Commento della guida
this site doesn't sell the Nook Color display. Where did you get yours?
