Salta al contenuto principale
Nite Ize Inova Microlight Casing Replacement
Jennifer Tabadero
Jennifer Tabadero e 2 altri collaboratori
Ultimo aggiornamento il January 6, 2015
1 - 5 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to change the case of a microlight.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nite Ize Inova Microlight Casing Replacement, Case Removal: passo 1, immagine 1 di 2 Nite Ize Inova Microlight Casing Replacement, Case Removal: passo 1, immagine 2 di 2
    • Insert the plastic opening tool into the seam of the device.
  2. Nite Ize Inova Microlight Casing Replacement, Battery Removal: passo 2, immagine 1 di 3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: passo 2, immagine 2 di 3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: passo 2, immagine 3 di 3
    • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
    • Repeat this step for the bottom remaining battery.
    • Do not pull up on the battery as this will bend the metal contact.
  3. Nite Ize Inova Microlight Casing Replacement, LED Light Removal: passo 3, immagine 1 di 3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: passo 3, immagine 2 di 3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: passo 3, immagine 3 di 3
    • Place the plastic opening tool below the LED lamp and push away from the device until you hear a click.
    • Continue to remove the LED lamp the with your fingers.
  4. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: passo 4, immagine 1 di 1
    • Place the plastic opening tool behind the logic board and bend away from the casing
  5. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: passo 5, immagine 1 di 1
    • The logic board will pop out with ease.
Conclusione
CSU Fullerton, Team 2-1, Bruce Fall 2014 Membro di CSU Fullerton, Team 2-1, Bruce Fall 2014
CSUF-BRUCE-F14S2G1
3 Membri
3 Guide realizzate
1Commento della guida
Great Job! found this one night while looking at my little blue light. Great tools, photos. +30
4-16-2017
F3ND1MUS - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 916
