Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement
Introduzione
Vai al passo 1This guide will show you the steps on installing the shoulder buttons. This will be helpful if the shoulder buttons are not working properly.
Only replace the faulty shoulder button(s).
Cosa ti serve
Pull down on the battery cover release lever and pull back to remove the cover.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use tweezers to remove the buttons.
Using tweezers remove the three grey button pads from the motherboard.
Remove the four 9-mm Phillips head screws with the Phillips #1 screwdriver.
Lift off the black plastic covers that secure the shoulder buttons.
Altre 5 persone hanno completato questa guida.
Un commento
Where can I buy replacement shoulder buttons? Mine are starting to get sticky and don't spring back as well as they used to. I've been looking but I can't seem to find them anywhere.
