Salta al contenuto principale
Nintendo Switch Pro Controller Front Button Replacement
Daniel Tagalog
Daniel Tagalog e 9 altri collaboratori
Ultimo aggiornamento il 16 apr 2025
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
The front buttons on a Nintendo switch pro controller are supposed to be free flowing and have lightning fast response time. If your controller is not performing at the highest level it can then that means you will keep losing games. The controller has to be the best it can possibly be so that you can play up to your ultimate potential. If your front buttons are sticky, unresponsive, or will not press down all the way, use this guide to remove and replace your buttons. This guide requires a Phillips #00 screwdriver for screw removal.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: passo 1, immagine 1 di 1
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    Be carefull, these screws are super easy to strip even with the right tools.
    Lukas Eberharter - Replica
    I tried editing these instructions after I had trouble with stripping screws, but it doesn't seem to take. The issue is that these are JIS and not Phillips screws. They are VERY similar looking but a Phillips head screwdriver will strip the screws.
    Isaac Webb - Replica
    I tried using a Philips #00 screwdriver but it didn’t work
    vincent ingrassia - Replica
    Don't even think about trying Phillips. There are some other guides online that say you'll be fine, but they're wrong. Even one attempt with Phillips WILL strip these, and you will never, ever get this controller open once that happens. Even with JIS they're really hard to get out and really easy to strip.
    Luke T. Allen - Replica
  2. Nintendo Switch Pro Controller Front Button Replacement, Remove the handle covers: passo 2, immagine 1 di 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the handle covers: passo 2, immagine 2 di 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the handle covers: passo 2, immagine 3 di 3
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: passo 3, immagine 1 di 1
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Nintendo Switch Pro Controller Front Button Replacement, Unclip the plastic cover: passo 4, immagine 1 di 3 Nintendo Switch Pro Controller Front Button Replacement, Unclip the plastic cover: passo 4, immagine 2 di 3 Nintendo Switch Pro Controller Front Button Replacement, Unclip the plastic cover: passo 4, immagine 3 di 3
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Nintendo Switch Pro Controller Front Button Replacement, Remove the clear plastic cover: passo 5, immagine 1 di 1
    • Remove the clear plastic cover.
  6. Nintendo Switch Pro Controller Front Button Replacement, Remove the battery: passo 6, immagine 1 di 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the battery: passo 6, immagine 2 di 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the battery: passo 6, immagine 3 di 3
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
  7. Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: passo 7, immagine 1 di 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: passo 7, immagine 2 di 3 Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: passo 7, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
    the 2 screws up at the top are unreachable with the standard fixit kit just a heads up
    drew - Replica
    Seconded. the screws are located too deep below the plastic slot, and the bit holding bulge is too wide for the small aperture (similarly with the flexible extension). the bit length is too shallow to reach.
    An alternative driver with a much narrower & longer shaft is required, which will likely not come with interchangeable bits.
    Douglas Selby -
    I would say it is possible to reach the top left screw, just not the top right - there is a gap in the top left that allows you to slightly bend the standard driver outward to turn it while still making adequate contact.
    El_Mechacontext - Replica
    An update: I was actually able to remove the top right one in a really hacky way - inserting the Phillips #0 bit into the #4 hex bit, and then using that in the standard driver. This added just enough length to successfully reach and make full contact with the screw!
    El_Mechacontext -
    Using the #4 hex bit as an extension was the exact "hack" I needed to get rid of the drift finally. Thank you. You're a lifesaver.
    Das #4 Hex Bit als Verlängerung für das Kreuzschlitz Bit zu nutzen ist zwar etwas eng, aber es erspart einem wirklich einen zusätzlichen Schraubendreher.
    Techn0magier -
  8. Nintendo Switch Pro Controller Front Button Replacement: passo 8, immagine 1 di 3 Nintendo Switch Pro Controller Front Button Replacement: passo 8, immagine 2 di 3 Nintendo Switch Pro Controller Front Button Replacement: passo 8, immagine 3 di 3
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
    Didn't realize there is adhesive holding the front cover onto the unit. It's located inside of the handles. Just a bit of force there helped, just be careful of the cable.
    Roger Perez - Replica
    this step is really hard
    XDchlapec - Replica
    You can use a pry tool to pry the part of the top shell covering the handles off the adhesive in order to make this step less like pulling teeth.
    Charlie - Replica
  9. Nintendo Switch Pro Controller Front Button Replacement, Open the flap: passo 9, immagine 1 di 2 Nintendo Switch Pro Controller Front Button Replacement, Open the flap: passo 9, immagine 2 di 2
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
    Having just completed this repair, I noted that this ribbon cable can disconnect on either side. It is easier to disconnect and reconnect from the other side than what is shown in my experience.
    acestronautical - Replica
    @acestronautical is right! much easier to remove the ribbon cable from the button board, connect to the base board and then connect back to the button board. Thank you @acestronautical
    Joe Rickerby - Replica
  10. Nintendo Switch Pro Controller Front Button Replacement, Disconnect the interconnect cable: passo 10, immagine 1 di 2 Nintendo Switch Pro Controller Front Button Replacement, Disconnect the interconnect cable: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
    You don't need to disconnect this as long as you are fine with keeping it close by so as not to rip the ribbon cable.
    Caden Helm - Replica
  11. Nintendo Switch Pro Controller Front Button Replacement, Remove the front case: passo 11, immagine 1 di 1
    • Remove the front case.
  12. Nintendo Switch Pro Controller Front Button Replacement, Remove the screws: passo 12, immagine 1 di 1
    • Remove the two 6.8 mm-long screws on the top circuit board using a Phillips screwdriver.
  13. Nintendo Switch Pro Controller Front Button Replacement, Open the ZIF connector: passo 13, immagine 1 di 2 Nintendo Switch Pro Controller Front Button Replacement, Open the ZIF connector: passo 13, immagine 2 di 2
    • Use a spudger to flip up the locking tab on the ZIF connector.
  14. Nintendo Switch Pro Controller Front Button Replacement: passo 14, immagine 1 di 2 Nintendo Switch Pro Controller Front Button Replacement: passo 14, immagine 2 di 2
    • Remove the black ribbon cable from its connector.
    • Only a small amount of force should be needed to remove the ribbon cable.
    What do I do if the connector snaps off? Is it fixable with solder or electrical tape or should I give up hope?
    Jack Frost - Replica
    This ribbon cable is difficult to reconnect, quality tweezers are required. I was unable to slide the ribbon cable in to where I could no longer see the traces. Take note of how much ribbon cable is exposed before disconnecting so that you can have an easier time judging when the cable is fully inserted upon reconnecting.
  15. Nintendo Switch Pro Controller Front Button Replacement: passo 15, immagine 1 di 2 Nintendo Switch Pro Controller Front Button Replacement: passo 15, immagine 2 di 2
    • Remove the trigger buttons from the plastic cover.
  16. Nintendo Switch Pro Controller Front Button Replacement, Unscrew front button board: passo 16, immagine 1 di 1
    • Use a Phillips screwdriver to remove the 5 mm-long screw securing the front button board.
    • There may be an additional screw. If so, remove it now.
  17. Nintendo Switch Pro Controller Front Button Replacement, Remove the board: passo 17, immagine 1 di 2 Nintendo Switch Pro Controller Front Button Replacement, Remove the board: passo 17, immagine 2 di 2
    • Remove the front button board.
Conclusione
Altre 8 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Daniel Tagalog
Membro da: 10/10/19
1.925 Reputazione
3 Guide realizzate
Cal Poly, Team S11-G2, Regan Fall 2019 Membro di Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Membri
44 Guide realizzate
4Commenti sulla guida
Hey Daniel! Thank you very much for this tutorial.
May I ask you, do you know the part code of this specific board or where I can find it online?? My pro controller d-pad came malfunctioning from factory and I think I’ll challenge myself to try and buy a new one to replace it.
Tassio - Replica
I broke the locking tab on the ZIF connector what can I do?
Jonathan Martinez - Replica
I’ve been looking myself and can’t find any replacement button board to buy - just asking again if anyone knows how to find or where to buy one?
Brandon Green - Replica
if anyone else is reading this article... I easily found a nice set of replacement buttons that fit well on zedlabz. they're made in china and they are good quality rigid plastic with pleasant texturizing so they are easy to grip and press. happy fixing!
George Harrison Fricklas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 56
Ultimi 30 Giorni: 305
Tutti i Tempi: 16,061
