Salta al contenuto principale
Nintendo Switch 2 Screen Replacement
Cosa ti serve
  1. Nintendo Switch 2 Screen Replacement, Power off the console: passo 1, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Power off the console: passo 1, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Power off the console: passo 1, immagine 3 di 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
  2. Nintendo Switch 2 Screen Replacement, Remove the bottom screws: passo 2, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the bottom screws: passo 2, immagine 2 di 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Switch 2 Screen Replacement, Remove the top screw: passo 3, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the top screw: passo 3, immagine 2 di 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
  4. Nintendo Switch 2 Screen Replacement, Heat the right side sticker: passo 4, immagine 1 di 1
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
  5. Nintendo Switch 2 Screen Replacement, Pry up the right side sticker: passo 5, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Pry up the right side sticker: passo 5, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Pry up the right side sticker: passo 5, immagine 3 di 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
  6. Nintendo Switch 2 Screen Replacement: passo 6, immagine 1 di 3 Nintendo Switch 2 Screen Replacement: passo 6, immagine 2 di 3 Nintendo Switch 2 Screen Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Jimmy
    $7.16
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
  7. Nintendo Switch 2 Screen Replacement, Heat the right side sticker: passo 7, immagine 1 di 1
    • Reheat the bottom of the right side until it's hot to the touch.
  8. Nintendo Switch 2 Screen Replacement, Remove the right side sticker: passo 8, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Remove the right side sticker: passo 8, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Remove the right side sticker: passo 8, immagine 3 di 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
  9. Nintendo Switch 2 Screen Replacement, Remove the left side sticker: passo 9, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Remove the left side sticker: passo 9, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Remove the left side sticker: passo 9, immagine 3 di 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
  10. Nintendo Switch 2 Screen Replacement, Remove the side screws: passo 10, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the side screws: passo 10, immagine 2 di 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
  11. Nintendo Switch 2 Screen Replacement, Open the kickstand: passo 11, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Open the kickstand: passo 11, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Open the kickstand: passo 11, immagine 3 di 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
  12. Nintendo Switch 2 Screen Replacement, Remove the back-side screws: passo 12, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the back-side screws: passo 12, immagine 2 di 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
  13. Nintendo Switch 2 Screen Replacement, Insert an opening pick: passo 13, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Insert an opening pick: passo 13, immagine 2 di 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
  14. Nintendo Switch 2 Screen Replacement: passo 14, immagine 1 di 2 Nintendo Switch 2 Screen Replacement: passo 14, immagine 2 di 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
  15. Nintendo Switch 2 Screen Replacement, Insert a second opening pick: passo 15, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Insert a second opening pick: passo 15, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Insert a second opening pick: passo 15, immagine 3 di 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
  16. Nintendo Switch 2 Screen Replacement: passo 16, immagine 1 di 2 Nintendo Switch 2 Screen Replacement: passo 16, immagine 2 di 2
    • Slide the first opening pick back to where it was first inserted.
  17. Nintendo Switch 2 Screen Replacement, Remove the back cover: passo 17, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Remove the back cover: passo 17, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Remove the back cover: passo 17, immagine 3 di 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
  18. Nintendo Switch 2 Screen Replacement: passo 18, immagine 1 di 3 Nintendo Switch 2 Screen Replacement: passo 18, immagine 2 di 3 Nintendo Switch 2 Screen Replacement: passo 18, immagine 3 di 3
    • Lift the back cover up from the bottom edge and remove it.
  19. Nintendo Switch 2 Screen Replacement, Remove the lower antenna screws: passo 19, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the lower antenna screws: passo 19, immagine 2 di 2
    • Use a JIS 00 driver to remove the three 4.4 mm‑long silver screws securing the lower antenna.
  20. Nintendo Switch 2 Screen Replacement, Remove the lower antenna: passo 20, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the lower antenna: passo 20, immagine 2 di 2
    • Use tweezers or your fingers to remove the lower antenna.
  21. Nintendo Switch 2 Screen Replacement, Remove the upper antenna screws: passo 21, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the upper antenna screws: passo 21, immagine 2 di 2
    • Use a JIS 00 driver to remove the two screws securing the upper antenna:
    • One 4.4 mm‑long silver screw
    • One 4.6 mm‑long green screw
  22. Nintendo Switch 2 Screen Replacement, Remove the upper antenna: passo 22, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the upper antenna: passo 22, immagine 2 di 2
    • Use tweezers or your fingers to remove the upper antenna.
  23. Nintendo Switch 2 Screen Replacement, Disconnect the lower antenna cable: passo 23, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Disconnect the lower antenna cable: passo 23, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Disconnect the lower antenna cable: passo 23, immagine 3 di 3
    • Insert an arm of angled tweezers under the metal neck of the white interconnect cable coaxial connector (located beneath the lower antenna) and lift straight up to disconnect it.
  24. Nintendo Switch 2 Screen Replacement, Disconnect the remaining antenna cables: passo 24, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Disconnect the remaining antenna cables: passo 24, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Disconnect the remaining antenna cables: passo 24, immagine 3 di 3
    • Repeat this procedure to disconnect the three central coaxial connectors from the board.
  25. Nintendo Switch 2 Screen Replacement, Disconnect the MicroSD connector: passo 25, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Disconnect the MicroSD connector: passo 25, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Disconnect the MicroSD connector: passo 25, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
  26. Nintendo Switch 2 Screen Replacement, Remove the shield plate screws: passo 26, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the shield plate screws: passo 26, immagine 2 di 2
    • Use a JIS 00 driver to remove the seven screws securing the shield plate:
    • Two 6.2 mm‑long silver screws
    • Five 4.4 mm‑long silver screws
  27. Nintendo Switch 2 Screen Replacement, Lift the shield plate: passo 27, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Lift the shield plate: passo 27, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Lift the shield plate: passo 27, immagine 3 di 3
    • Insert the flat end of a spudger between the shield plate and the processor's heat sink, next to the square (⛶) marking on the shield plate.
    • Twist the spudger to lift the shield plate and separate the thermal putty bonded to it. Keep lifting the shield plate until you don't feel resistance.
  28. Nintendo Switch 2 Screen Replacement: passo 28, immagine 1 di 3 Nintendo Switch 2 Screen Replacement: passo 28, immagine 2 di 3 Nintendo Switch 2 Screen Replacement: passo 28, immagine 3 di 3
    • Lift the left edge of the shield plate to ensure it's fully separated from the thermal putty.
    • Gently set the shield plate back down.
  29. Nintendo Switch 2 Screen Replacement, Unroute the gray antenna cable: passo 29, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Unroute the gray antenna cable: passo 29, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Unroute the gray antenna cable: passo 29, immagine 3 di 3
    • Insert one arm of angled tweezers underneath the gray antenna cable at the bottom-right corner of the console.
    • Lift the cable out of the black clip securing it to the frame.
  30. Nintendo Switch 2 Screen Replacement: passo 30, immagine 1 di 3 Nintendo Switch 2 Screen Replacement: passo 30, immagine 2 di 3 Nintendo Switch 2 Screen Replacement: passo 30, immagine 3 di 3
    • Unroute the gray antenna cable from its channel along the right edge of the console.
  31. Nintendo Switch 2 Screen Replacement: passo 31, immagine 1 di 2 Nintendo Switch 2 Screen Replacement: passo 31, immagine 2 di 2
    • Lift and slide the shield plate away from the right edge of the console until the gray antenna cable is completely free.
  32. Nintendo Switch 2 Screen Replacement, Remove the shield plate: passo 32, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the shield plate: passo 32, immagine 2 di 2
    • Pick up and remove the shield plate.
  33. Nintendo Switch 2 Screen Replacement, Disconnect the battery: passo 33, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Disconnect the battery: passo 33, immagine 2 di 2
    • Insert the flat end of a spudger underneath the flat-topped battery connector, located next to the battery, and pry up to disconnect it.
  34. Nintendo Switch 2 Screen Replacement, Clean the heat pipe: passo 34, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Clean the heat pipe: passo 34, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Clean the heat pipe: passo 34, immagine 3 di 3
    Arctic Silver ArctiClean
    $9.99
    • If you don't have replacement thermal putty, use the flat end of a spudger to distribute the old putty evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate, then skip this step.
    • Use the flat end of a spudger to scrape off the thermal putty on top of the copper heat pipe.
    • Apply high-concentration (90% or higher) isopropyl alcohol or thermal material remover to a cotton swab or lint-free cloth and wipe away any remaining thermal putty on both the heat pipe and shield plate.
    • Don't use a paper towel or rag, as they may scratch the shield plate.
  35. Nintendo Switch 2 Screen Replacement, Remove the heat sink screws: passo 35, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the heat sink screws: passo 35, immagine 2 di 2
    • Use a JIS 00 driver to remove the four 3.4 mm‑long silver screws securing the heat sink.
  36. Nintendo Switch 2 Screen Replacement, Free the heat sink: passo 36, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Free the heat sink: passo 36, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Free the heat sink: passo 36, immagine 3 di 3
    • Insert the flat end of a spudger between the heat sink and the processor's heat spreader.
    • Twist the spudger to lift the heat sink and separate the thermal paste bonded to it.
  37. Nintendo Switch 2 Screen Replacement, Remove the heat sink: passo 37, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Remove the heat sink: passo 37, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Remove the heat sink: passo 37, immagine 3 di 3
    • Lift the heat sink slowly to avoid bending its thin copper heat pipe.
    • Slowly lift the heat sink from the front, until the aluminum fin stack at the back is detached from the adhesive beneath it.
    • Remove the heat sink.
  38. Nintendo Switch 2 Screen Replacement, Clean the thermal paste: passo 38, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Clean the thermal paste: passo 38, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Clean the thermal paste: passo 38, immagine 3 di 3
    $9.99
    • Use high-concentration (90% or higher) isopropyl alcohol or thermal material remover to soak the thermal paste on the processor's heat spreader for one minute.
    • Use a lint-free cloth or cotton swabs to wipe away the thermal paste.
    • Repeat this process until the processor's heat spreader is clean.
  39. Nintendo Switch 2 Screen Replacement: passo 39, immagine 1 di 2 Nintendo Switch 2 Screen Replacement: passo 39, immagine 2 di 2
    • If you're replacing your heat sink, skip this step.
    • Repeat this process to clean the thermal paste off the bottom of the heat sink.
  40. Nintendo Switch 2 Screen Replacement, Disconnect the fan: passo 40, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Disconnect the fan: passo 40, immagine 2 di 2
    • Use the point of a spudger to flip up the locking flap on the fan cable ZIF connector, located next to the fan on the console's board.
  41. Nintendo Switch 2 Screen Replacement: passo 41, immagine 1 di 3 Nintendo Switch 2 Screen Replacement: passo 41, immagine 2 di 3 Nintendo Switch 2 Screen Replacement: passo 41, immagine 3 di 3
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • If you're using tweezers, pull the cable out by its "wings" instead of gripping the cable itself.
  42. Nintendo Switch 2 Screen Replacement, Remove the fan screws: passo 42, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the fan screws: passo 42, immagine 2 di 2
    • Use a JIS 00 driver to remove the three 5.2 mm‑long silver screws securing the fan.
  43. Nintendo Switch 2 Screen Replacement, Remove the fan: passo 43, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Remove the fan: passo 43, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Remove the fan: passo 43, immagine 3 di 3
    • Slide the fan out of its recess to free its cable, then pick it up to remove it.
  44. Nintendo Switch 2 Screen Replacement, Disconnect the screen: passo 44, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Disconnect the screen: passo 44, immagine 2 di 2
    • Use your finger or the flat end of a spudger to flip up the locking flap on the screen cable ZIF connector.
  45. Nintendo Switch 2 Screen Replacement: passo 45, immagine 1 di 2 Nintendo Switch 2 Screen Replacement: passo 45, immagine 2 di 2
    • Use tweezers or your fingers to gently pull the cable out of its connector.
  46. Nintendo Switch 2 Screen Replacement, Heat the bottom edge: passo 46, immagine 1 di 1
    • Flip the console over so the screen is facing up.
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the console hotter than this—the frame is susceptible to heat damage.
  47. Nintendo Switch 2 Screen Replacement, Insert an opening pick: passo 47, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Insert an opening pick: passo 47, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Insert an opening pick: passo 47, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the screen, above the right speaker and ventilation cutouts.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    • If you can't create a gap large enough to fit an opening pick, reheat the bottom edge of the screen and try again.
  48. Nintendo Switch 2 Screen Replacement, Separate the bottom adhesive: passo 48, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Separate the bottom adhesive: passo 48, immagine 2 di 2
    • Slide your pick across the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom left corner to prevent the adhesive from resealing.
  49. Nintendo Switch 2 Screen Replacement, Heat the left edge: passo 49, immagine 1 di 1
  50. Nintendo Switch 2 Screen Replacement, Separate the left adhesive: passo 50, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Separate the left adhesive: passo 50, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Separate the left adhesive: passo 50, immagine 3 di 3
    • Insert a second opening pick next to the first one and slide it up the left edge of the screen.
  51. Nintendo Switch 2 Screen Replacement, Separate the remaining adhesives: passo 51, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Separate the remaining adhesives: passo 51, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Separate the remaining adhesives: passo 51, immagine 3 di 3
    • Repeat the heating and sliding procedure along the remaining screen edges.
  52. Nintendo Switch 2 Screen Replacement, Remove the screen: passo 52, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Remove the screen: passo 52, immagine 2 di 2
    • Lift the screen off the frame to remove it.
    • If any adhesive strips are still stuck to the frame, peel it up with slow, steady force to release it.
  53. Nintendo Switch 2 Screen Replacement, Disassembly complete: passo 53, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  54. Nintendo Switch 2 Screen Replacement, Clean the frame: passo 54, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Clean the frame: passo 54, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Clean the frame: passo 54, immagine 3 di 3
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • Use the point of a spudger to scrape off any adhesive left on the frame.
    • Apply a bit of isopropyl alcohol to a cotton swab or lint-free cloth and clean the frame until it's free of adhesive residue.
    • Alternatively, use our adhesive cleanup kit.
  55. Nintendo Switch 2 Screen Replacement, Apply new adhesive: passo 55, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Apply new adhesive: passo 55, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Apply new adhesive: passo 55, immagine 3 di 3
    Tesa 61395 Tape
    $2.99
    • If your replacement screen comes with adhesive pre-applied, skip this step.
    • Use your fingers to install strips of thin, double-sided tape to the raised lip along the edges of the frame. Use 1 mm strips for the top and bottom edges and 2 mm strips for the sides.
  56. Nintendo Switch 2 Screen Replacement, Prepare the adhesive: passo 56, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Prepare the adhesive: passo 56, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Prepare the adhesive: passo 56, immagine 3 di 3
    • Use angled tweezers to peel off all liners from the adhesive.
  57. Nintendo Switch 2 Screen Replacement, Install the screen cable: passo 57, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Install the screen cable: passo 57, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Install the screen cable: passo 57, immagine 3 di 3
    • Don't adhere the screen to the frame yet.
    • Align the screen's cable with its cutout in the frame.
    • Route the cable through its cutout, ensuring it reaches its connector on the board.
  58. Nintendo Switch 2 Screen Replacement, Adhere the screen: passo 58, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Adhere the screen: passo 58, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Adhere the screen: passo 58, immagine 3 di 3
    • Align the right edge of the screen with its recess in the frame.
    • Press the right edge of the screen into place, then work your way to the left edge until the entire screen is adhered to the frame.
    • If the screen starts to feel misaligned as you work your way down, lift it back up and try again. Try to avoid stretching or creasing the adhesive.
  59. Nintendo Switch 2 Screen Replacement, Connect the screen cable: passo 59, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Connect the screen cable: passo 59, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Connect the screen cable: passo 59, immagine 3 di 3
    • Use tweezers or your fingers to slide the screen cable into its ZIF connector until it's fully seated.
    • If you're using tweezers, you can use the flat end of a spudger to help guide the cable into its connector.
    • Flip the hinged locking flap down to secure the cable.
  60. Nintendo Switch 2 Screen Replacement, Install the fan: passo 60, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Install the fan: passo 60, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Install the fan: passo 60, immagine 3 di 3
    • Slide the fan into its recess. Ensure its cable slides underneath the edge of the board.
    • Align the fan with its screw posts on the frame.
  61. Nintendo Switch 2 Screen Replacement: passo 61, immagine 1 di 2 Nintendo Switch 2 Screen Replacement: passo 61, immagine 2 di 2
    • Use a JIS 00 driver to install the three 5.2 mm‑long silver screws securing the fan.
  62. Nintendo Switch 2 Screen Replacement, Connect the fan: passo 62, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Connect the fan: passo 62, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Connect the fan: passo 62, immagine 3 di 3
    • Use tweezers or your fingers to slide the fan cable into its ZIF connector until it's fully seated.
    • If you're using tweezers, you can use a spudger to help guide the cable into its connector.
  63. Nintendo Switch 2 Screen Replacement, Install thermal paste: passo 63, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Install thermal paste: passo 63, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Install thermal paste: passo 63, immagine 3 di 3
    iFixit Thermal Paste
    $9.95
    • Apply a bead of new thermal paste to the center of the processor's copper heat spreader, roughly the size of a pea.
  64. Nintendo Switch 2 Screen Replacement, Install the heat sink: passo 64, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Install the heat sink: passo 64, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Install the heat sink: passo 64, immagine 3 di 3
    • Set the heat sink's aluminum fins into its recess behind the fan, then lower the heat sink onto the board.
  65. Nintendo Switch 2 Screen Replacement: passo 65, immagine 1 di 2 Nintendo Switch 2 Screen Replacement: passo 65, immagine 2 di 2
    • Use a JIS 00 driver to partially install the four 3.4 mm‑long silver screws securing the heat sink.
    • Tighten the screws in an X pattern. For example: bottom left, top right, bottom right, then top left.
  66. Nintendo Switch 2 Screen Replacement, Connect the battery: passo 66, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Connect the battery: passo 66, immagine 2 di 2
    • Align the battery connector over its socket on the board.
    • Use your finger or the flat end of a spudger to press the battery connector onto its socket until it's fully seated.
  67. Nintendo Switch 2 Screen Replacement, Apply thermal putty: passo 67, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Apply thermal putty: passo 67, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Apply thermal putty: passo 67, immagine 3 di 3
    iFixit Thermal Putty
    $9.95
    • Apply a line of new thermal putty down the center of the heat pipe, roughly the thickness of a pea.
  68. Nintendo Switch 2 Screen Replacement, Route the gray antenna cable: passo 68, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Route the gray antenna cable: passo 68, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Route the gray antenna cable: passo 68, immagine 3 di 3
    • Hold the top‑right corner of the shield plate above the top‑right corner of the console.
    • Route the gray antenna cable underneath the black hook near the top corner of the frame.
  69. Nintendo Switch 2 Screen Replacement, Lower the shield plate: passo 69, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Lower the shield plate: passo 69, immagine 2 di 2
    • Lower the shield plate into place and align it with its screw holes.
  70. Nintendo Switch 2 Screen Replacement, Finish routing the gray antenna cable: passo 70, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Finish routing the gray antenna cable: passo 70, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Finish routing the gray antenna cable: passo 70, immagine 3 di 3
    • Route the gray antenna cable down its channel on the right edge of the frame.
  71. Nintendo Switch 2 Screen Replacement: passo 71, immagine 1 di 3 Nintendo Switch 2 Screen Replacement: passo 71, immagine 2 di 3 Nintendo Switch 2 Screen Replacement: passo 71, immagine 3 di 3
    • Press the gray antenna cable into its groove at the bottom of its channel, and continue routing until it's secured to the clip at the bottom of the frame.
  72. Nintendo Switch 2 Screen Replacement, Install the shield plate screws: passo 72, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Install the shield plate screws: passo 72, immagine 2 di 2
    • Use a JIS 00 driver to install the seven screws securing the shield plate:
  73. Nintendo Switch 2 Screen Replacement, Connect the MicroSD connector: passo 73, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Connect the MicroSD connector: passo 73, immagine 2 di 2
    • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  74. Nintendo Switch 2 Screen Replacement, Connect the antenna cables: passo 74, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Connect the antenna cables: passo 74, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Connect the antenna cables: passo 74, immagine 3 di 3
    • Use tweezers to hold the lower antenna coaxial connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
    • Repeat this process to connect the three central coaxial connectors to their respective sockets.
    • The black cable connects to the socket closest to the fan, the white to the middle, and the gray the furthest away.
  75. Nintendo Switch 2 Screen Replacement, Install the upper antenna: passo 75, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Install the upper antenna: passo 75, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Install the upper antenna: passo 75, immagine 3 di 3
    • Use tweezers or your fingers to align the upper antenna with its screw holes and black alignment pegs and set it into place.
    • Use a JIS 00 driver to install the two screws securing the upper antenna:
  76. Nintendo Switch 2 Screen Replacement, Install the lower antenna: passo 76, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Install the lower antenna: passo 76, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Install the lower antenna: passo 76, immagine 3 di 3
    • Use tweezers or your fingers to align the lower antenna with its screw holes and gray alignment pegs and set it into place.
    • Use a JIS 00 driver to install the three 4.4 mm‑long screws securing the lower antenna.
  77. Nintendo Switch 2 Screen Replacement, Prepare the back cover: passo 77, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Prepare the back cover: passo 77, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Prepare the back cover: passo 77, immagine 3 di 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
  78. Nintendo Switch 2 Screen Replacement, Install the back cover: passo 78, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Install the back cover: passo 78, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Install the back cover: passo 78, immagine 3 di 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
  79. Nintendo Switch 2 Screen Replacement: passo 79, immagine 1 di 2 Nintendo Switch 2 Screen Replacement: passo 79, immagine 2 di 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
  80. Nintendo Switch 2 Screen Replacement, Install the back-side screws: passo 80, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Install the back-side screws: passo 80, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Install the back-side screws: passo 80, immagine 3 di 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
  81. Nintendo Switch 2 Screen Replacement, Install the side screws: passo 81, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Install the side screws: passo 81, immagine 2 di 2
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
  82. Nintendo Switch 2 Screen Replacement, Test the console: passo 82, immagine 1 di 2 Nintendo Switch 2 Screen Replacement, Test the console: passo 82, immagine 2 di 2
    • Power on the console and test functionality to ensure it's working as expected.
  83. Nintendo Switch 2 Screen Replacement, Install the stickers: passo 83, immagine 1 di 3 Nintendo Switch 2 Screen Replacement, Install the stickers: passo 83, immagine 2 di 3 Nintendo Switch 2 Screen Replacement, Install the stickers: passo 83, immagine 3 di 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
  84. Nintendo Switch 2 Screen Replacement: passo 84, immagine 1 di 3 Nintendo Switch 2 Screen Replacement: passo 84, immagine 2 di 3 Nintendo Switch 2 Screen Replacement: passo 84, immagine 3 di 3
    • Repeat this procedure to install the left side sticker.
Conclusione
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
Membro da: 03/24/24
36.897 Reputazione
224 Guide realizzate
2Commenti sulla guida
Where can I find replacement screen?
Ashutosh Sah - Replica
They're not available yet! We'll update the guide once we have the part.
Nick Schultz -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 31
Ultimi 7 Giorni: 265
Ultimi 30 Giorni: 1,134
Tutti i Tempi: 2,720
