Salta al contenuto principale
Nintendo Switch 2 MicroSD Card Reader Replacement
Cosa ti serve
  1. Nintendo Switch 2 MicroSD Card Reader Replacement, Power off the console: passo 1, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Power off the console: passo 1, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Power off the console: passo 1, immagine 3 di 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the bottom screws: passo 2, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the bottom screws: passo 2, immagine 2 di 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the top screw: passo 3, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the top screw: passo 3, immagine 2 di 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
    Chiedi a FixBot
    Aggiungi Commento
  4. Nintendo Switch 2 MicroSD Card Reader Replacement, Heat the right side sticker: passo 4, immagine 1 di 1
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nintendo Switch 2 MicroSD Card Reader Replacement, Pry up the right side sticker: passo 5, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Pry up the right side sticker: passo 5, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Pry up the right side sticker: passo 5, immagine 3 di 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 6, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 6, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 6, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Jimmy
    $7.95
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
    Chiedi a FixBot
    Aggiungi Commento
  7. Nintendo Switch 2 MicroSD Card Reader Replacement, Heat the right side sticker: passo 7, immagine 1 di 1
    • Reheat the bottom of the right side until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  8. Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the right side sticker: passo 8, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the right side sticker: passo 8, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the right side sticker: passo 8, immagine 3 di 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  9. Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the left side sticker: passo 9, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the left side sticker: passo 9, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the left side sticker: passo 9, immagine 3 di 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
    Chiedi a FixBot
    Aggiungi Commento
  10. Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the side screws: passo 10, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the side screws: passo 10, immagine 2 di 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
    Chiedi a FixBot
    Aggiungi Commento
  11. Nintendo Switch 2 MicroSD Card Reader Replacement, Open the kickstand: passo 11, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Open the kickstand: passo 11, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Open the kickstand: passo 11, immagine 3 di 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
    Chiedi a FixBot
    Aggiungi Commento
  12. Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the back-side screws: passo 12, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the back-side screws: passo 12, immagine 2 di 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
    Chiedi a FixBot
    Aggiungi Commento
  13. Nintendo Switch 2 MicroSD Card Reader Replacement, Insert an opening pick: passo 13, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Insert an opening pick: passo 13, immagine 2 di 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
    Chiedi a FixBot
    Aggiungi Commento
  14. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 14, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 14, immagine 2 di 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
    Chiedi a FixBot
    Aggiungi Commento
  15. Nintendo Switch 2 MicroSD Card Reader Replacement, Insert a second opening pick: passo 15, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Insert a second opening pick: passo 15, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Insert a second opening pick: passo 15, immagine 3 di 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
    Chiedi a FixBot
    Aggiungi Commento
  16. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 16, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 16, immagine 2 di 2
    • Slide the first opening pick back to where it was first inserted.
    Chiedi a FixBot
    Aggiungi Commento
  17. Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the back cover: passo 17, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the back cover: passo 17, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the back cover: passo 17, immagine 3 di 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
    Chiedi a FixBot
    Aggiungi Commento
  18. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 18, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 18, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 18, immagine 3 di 3
    • Lift the back cover up from the bottom edge and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  19. Nintendo Switch 2 MicroSD Card Reader Replacement, Disconnect the MicroSD card reader: passo 19, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Disconnect the MicroSD card reader: passo 19, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Disconnect the MicroSD card reader: passo 19, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
    Chiedi a FixBot
    Aggiungi Commento
  20. Nintendo Switch 2 MicroSD Card Reader Replacement, Lift the tape: passo 20, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Lift the tape: passo 20, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Lift the tape: passo 20, immagine 3 di 3
    • Insert the point of a spudger underneath the black tape securing the MicroSD card reader.
    • Slowly lift the tape off the card reader.
    • Leave the tape attached to the shield plate—it'll be reused during reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  21. Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the cable bracket: passo 21, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the cable bracket: passo 21, immagine 2 di 2
    • Use a JIS 00 driver to remove the 1.6 mm‑long black screw securing the bracket over the MicroSD card reader's cable.
    Chiedi a FixBot
    Aggiungi Commento
  22. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 22, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 22, immagine 2 di 2
    • Pick up and remove the bracket securing the card reader's cable.
    Chiedi a FixBot
    Aggiungi Commento
  23. Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the MicroSD card reader: passo 23, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Remove the MicroSD card reader: passo 23, immagine 2 di 2
    • Use a JIS 00 driver to remove the 4.4 mm‑long silver screw securing the MicroSD card reader.
    Chiedi a FixBot
    Aggiungi Commento
  24. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 24, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 24, immagine 2 di 2
    • Use your fingers or the flat end of a spudger to lift the MicroSD card reader to separate the adhesive securing it to the shield plate.
    Chiedi a FixBot
    Aggiungi Commento
  25. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 25, immagine 1 di 1
    • Remove the MicroSD card reader
    Chiedi a FixBot
    Aggiungi Commento
  26. Nintendo Switch 2 MicroSD Card Reader Replacement, Disassembly complete: passo 26, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
    Chiedi a FixBot
    Aggiungi Commento
  27. Nintendo Switch 2 MicroSD Card Reader Replacement, Install the MicroSD card reader: passo 27, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Install the MicroSD card reader: passo 27, immagine 2 di 2
    • Align the MicroSD card reader with its pegs on the shield plate and set it into place.
    Chiedi a FixBot
    Aggiungi Commento
  28. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 28, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 28, immagine 2 di 2
    • Use a JIS 00 driver to install the 4.4 mm‑long silver screw securing the MicroSD card reader.
    Chiedi a FixBot
    Aggiungi Commento
  29. Nintendo Switch 2 MicroSD Card Reader Replacement, Install the cable bracket: passo 29, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Install the cable bracket: passo 29, immagine 2 di 2
    • Set the bracket on top of the MicroSD card reader's cable, aligned with its screw hole.
    • Ensure the black tab on the bottom of the bracket sits between the shield plate and card reader's cable.
    Chiedi a FixBot
    Aggiungi Commento
  30. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 30, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 30, immagine 2 di 2
    • Use a JIS 00 driver to install the 1.6 mm‑long black screw securing the cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  31. Nintendo Switch 2 MicroSD Card Reader Replacement, Press down the tape: passo 31, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Press down the tape: passo 31, immagine 2 di 2
    • Press the black tape onto the top of the MicroSD card reader.
    Chiedi a FixBot
    Aggiungi Commento
  32. Nintendo Switch 2 MicroSD Card Reader Replacement, Connect the MicroSD card reader: passo 32, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Connect the MicroSD card reader: passo 32, immagine 2 di 2
    • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
    • Don't try to force the connector into place. If you're having trouble, lift it and try again.
    Chiedi a FixBot
    Aggiungi Commento
  33. Nintendo Switch 2 MicroSD Card Reader Replacement, Prepare the back cover: passo 33, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Prepare the back cover: passo 33, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Prepare the back cover: passo 33, immagine 3 di 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
    Chiedi a FixBot
    Aggiungi Commento
  34. Nintendo Switch 2 MicroSD Card Reader Replacement, Install the back cover: passo 34, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Install the back cover: passo 34, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Install the back cover: passo 34, immagine 3 di 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
    Chiedi a FixBot
    Aggiungi Commento
  35. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 35, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 35, immagine 2 di 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
    Chiedi a FixBot
    Aggiungi Commento
  36. Nintendo Switch 2 MicroSD Card Reader Replacement, Install the back-side screws: passo 36, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Install the back-side screws: passo 36, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Install the back-side screws: passo 36, immagine 3 di 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
    Chiedi a FixBot
    Aggiungi Commento
  37. Nintendo Switch 2 MicroSD Card Reader Replacement, Install the side screws: passo 37, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Install the side screws: passo 37, immagine 2 di 2
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
    Chiedi a FixBot
    Aggiungi Commento
  38. Nintendo Switch 2 MicroSD Card Reader Replacement, Test the console: passo 38, immagine 1 di 2 Nintendo Switch 2 MicroSD Card Reader Replacement, Test the console: passo 38, immagine 2 di 2
    • Power on the console and test functionality to ensure it's working as expected.
    Chiedi a FixBot
    Aggiungi Commento
  39. Nintendo Switch 2 MicroSD Card Reader Replacement, Install the stickers: passo 39, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Install the stickers: passo 39, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement, Install the stickers: passo 39, immagine 3 di 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
    Chiedi a FixBot
    Aggiungi Commento
  40. Nintendo Switch 2 MicroSD Card Reader Replacement: passo 40, immagine 1 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 40, immagine 2 di 3 Nintendo Switch 2 MicroSD Card Reader Replacement: passo 40, immagine 3 di 3
    • Repeat this procedure to install the left side sticker.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
Membro da: 03/24/24
57.223 Reputazione
316 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 58
Ultimi 30 giorni: 267
Tutti i Tempi: 1,784
