Salta al contenuto principale
Nintendo GameCube Controller Triggers Replacement
Sean Michel
Sean Michel e 4 altri collaboratori
Ultimo aggiornamento il 23 set 2024
5 - 7 minuti
Moderato
Introduzione
Vai al passo 1
The Left and Right triggers are located on the back side of the controller near the cord. The triggers are spring loaded.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nintendo GameCube Controller Triggers Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Triggers Replacement: passo 2, immagine 1 di 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
    Rukir Gaming - Replica
  3. Nintendo GameCube Controller Triggers Replacement, Z Button: passo 3, immagine 1 di 2 Nintendo GameCube Controller Triggers Replacement, Z Button: passo 3, immagine 2 di 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
    Justin Sebastian - Replica
  4. Nintendo GameCube Controller Triggers Replacement, Circuit Board: passo 4, immagine 1 di 1
    • Carefully unhook the cable that is looped around the peg.
    Um can soneone explain the peg and cable part? I dont understand it...
    Tyler Goamez - Replica
    I would say that the cable is somehow "hooked" to the case and you have to get the cable away from the case so that you can pull out the board
    My1 -
  5. Nintendo GameCube Controller Triggers Replacement: passo 5, immagine 1 di 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Triggers Replacement, Triggers: passo 6, immagine 1 di 1
    • Remove the two 8.9mm Phillips Head #0 screws.
  7. Nintendo GameCube Controller Triggers Replacement: passo 7, immagine 1 di 1
    • Remove black cover.
  8. Nintendo GameCube Controller Triggers Replacement: passo 8, immagine 1 di 3 Nintendo GameCube Controller Triggers Replacement: passo 8, immagine 2 di 3 Nintendo GameCube Controller Triggers Replacement: passo 8, immagine 3 di 3
    • To remove the trigger assembly, depress the trigger with your index finger as if you are using the controller normally.
    • Hold the grey square bracket onside of the controller with your thumb.
    • Keep your fingers in the same place while rotating upwards towards you to remove trigger assembly.
  9. Nintendo GameCube Controller Triggers Replacement: passo 9, immagine 1 di 1
    • Pull the metal clip from the trigger.
Conclusione
In order to remove the other trigger, simply repeat Steps 6 through Step 9 on the right side.
Altre 11 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Sean Michel
Membro da: 01/14/13
2.562 Reputazione
8 Guide realizzate
Cal Poly, Team 19-44, Regan Winter 2013 Membro di Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Membri
31 Guide realizzate
3Commenti sulla guida
Don't forget to aline the trigger slider holes and the slider pins on the board when putting it all back together.
buttpug - Replica
Hallo ich habe da mal eine Frage. Ist es möglich die Empfindlichkeit der Trigger zu beeinflussen ? Leider reagieren sie erst sehr spät da mann den Knopf sehr weit hereindrücken muss.
danke schon mal
Otti
Ottitrotti - Replica
The trigger slider hole doesn’t sit well on the slider pins any suggestions ?
cHiLLz747 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 97
Tutti i Tempi: 28,644
