Salta al contenuto principale
Nikon D3100 LCD Screen Replacement
Jet Mejia
Jet Mejia e 9 altri collaboratori
Ultimo aggiornamento il 12 feb 2025
20 minuti
Moderato
Introduzione
Vai al passo 1
If your Nikon D3100 LCD screen is cracked, chipped, or flickering it may need to be replaced. Follow this guide to replace the LCD screen. But first take a look at this troubleshooting page to check if the problem is truly the LCD screen and not a setting issue.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nikon D3100 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver for all of the screws.
    • Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
  2. Nikon D3100 LCD Screen Replacement: passo 2, immagine 1 di 2 Nikon D3100 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Remove four of the 3mm screws around the eye piece located on the top of the back panel, including the screw hidden behind the auto focus label.
    • Remove the 3mm screw behind the rubber grip on the top right of the back panel.
  3. Nikon D3100 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Peel back the rubber grip on the right side of the camera using a spudger.
    • You may need a heating pad to melt the glue holding the rubber grip to the camera. If using the heating pad, use caution and handle carefully.
    • Remove two of the 5mm screws under the rubber grip.
  4. Nikon D3100 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove two of the 4mm screws on the left side of the camera.
  5. Nikon D3100 LCD Screen Replacement: passo 5, immagine 1 di 2 Nikon D3100 LCD Screen Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
    • Be careful not to pull the panel out too fast or the ribbon may be damaged.
    • Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
    • Separate the back panel from the main body of the camera.
  6. Nikon D3100 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Be careful when separating the metal plate from the back panel because the speaker wire is connected to the metal plate. It can easily be torn if caution is not taken.
    • Remove nine of the 3mm screws connecting the metal plate to the plastic panel.
  7. Nikon D3100 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the tape covering the ribbons. Be careful not to break the tape.
  8. Nikon D3100 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Remove the two ribbons connecting the LCD screen to the metal plate using the same method from Step 5.
  9. Nikon D3100 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Remove the old LCD screen from metal plate.
Conclusione
Altre 8 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Jet Mejia
Membro da: 09/26/16
662 Reputazione
3 Guide realizzate
USF Tampa, Team 14-1, Eyestone Fall 2016 Membro di USF Tampa, Team 14-1, Eyestone Fall 2016
USFT-EYESTONE-F16S14G1
3 Membri
4 Guide realizzate
5Commenti sulla guida
Very helpful guide, so happy to have a non-cracked screen again!
Rob Cuthbertson - Replica
now, where can i buy this replacement screen here in the Philippines?
leumas_erbutco - Replica
does anyone have the part number for the replacement screen?
Lee Caterson - Replica
Très bien ce document, seulement l'écran LCD pour Nikon D3100 semble introuvable, et épuisé !!! Avez-vous une adresse valable pour commander?
gtre - Replica
Hello, regarde ici ça devrait correspondre:
https://fra.grandado.com/products/origin...
Lou Lou - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 118
Tutti i Tempi: 14,513
